How to Remove the Stand on a PlayStation 5
  1. How to Remove the Stand on a PlayStation 5, Remove the stand screw: step 1, image 1 of 1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. How to Remove the Stand on a PlayStation 5, Remove the vertical stand: step 2, image 1 of 2 How to Remove the Stand on a PlayStation 5, Remove the vertical stand: step 2, image 2 of 2
    • Lift straight up to remove the stand.
  3. How to Remove the Stand on a PlayStation 5, Store the stand screw: step 3, image 1 of 2 How to Remove the Stand on a PlayStation 5, Store the stand screw: step 3, image 2 of 2
    • Insert the screw into the cubby on the bottom of the stand.
  4. How to Remove the Stand on a PlayStation 5, Cap the screw hole: step 4, image 1 of 3 How to Remove the Stand on a PlayStation 5, Cap the screw hole: step 4, image 2 of 3 How to Remove the Stand on a PlayStation 5, Cap the screw hole: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. How to Remove the Stand on a PlayStation 5, Close the cubby: step 5, image 1 of 3 How to Remove the Stand on a PlayStation 5, Close the cubby: step 5, image 2 of 3 How to Remove the Stand on a PlayStation 5, Close the cubby: step 5, image 3 of 3
    • Twist the stand counterclockwise to close the cubby.
  6. How to Remove the Stand on a PlayStation 5, Remove the horizontal stand: step 6, image 1 of 2 How to Remove the Stand on a PlayStation 5, Remove the horizontal stand: step 6, image 2 of 2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
2 other people completed this guide.
Robert Boyd
26,693 Reputation
94 Guides authored
0 Comments
Past 24 Hours: 28
Past 7 Days: 230
Past 30 Days: 1,117
All Time: 35,233
