How to Repair Cracks in a Cement Wall
  1. How to Repair Cracks in a Cement Wall, How to Repair Cracks in a Cement Wall: step 1, image 1 of 3 How to Repair Cracks in a Cement Wall, How to Repair Cracks in a Cement Wall: step 1, image 2 of 3 How to Repair Cracks in a Cement Wall, How to Repair Cracks in a Cement Wall: step 1, image 3 of 3
    • Remove the loose pieces of the wall in and around the crack.
    • Widen the crack to about an inch thick with an automatic angled concrete grinder.
    • A manual grinder may also work but will require more physical effort compared to the automatic grinder.
    • Use caution when operating power tools.
  2. How to Repair Cracks in a Cement Wall: step 2, image 1 of 3 How to Repair Cracks in a Cement Wall: step 2, image 2 of 3 How to Repair Cracks in a Cement Wall: step 2, image 3 of 3
    • Follow the instructions on the cement patcher mix until the product is a paste consistency.
    • Soak a sponge in water and wet the now larger crack. Be sure to get water into the entire crack so that the area is moist.
    • Use a trowel to fill the mix into the crevices.
    • You may also use a steel putty knife or margin trowel.
    • Caution: Wear gloves to avoid getting paste onto your hands. Contact with skin could cause second or third-degree chemical burns.
  3. How to Repair Cracks in a Cement Wall: step 3, image 1 of 3 How to Repair Cracks in a Cement Wall: step 3, image 2 of 3 How to Repair Cracks in a Cement Wall: step 3, image 3 of 3
    • Rewet the sponge and begin to smooth the patch mix into the wall.
    • A smooth blend will ensure the product stocks evenly across your wall and allows it to blend in.
  4. How to Repair Cracks in a Cement Wall: step 4, image 1 of 2 How to Repair Cracks in a Cement Wall: step 4, image 2 of 2
    • Allow the patcher mix to dry.
    • Drying times vary depending on the product and may take up to 48 hours.
    • Place tape in straight lines parallel to the edges of your dry plastered area.
  5. How to Repair Cracks in a Cement Wall: step 5, image 1 of 2 How to Repair Cracks in a Cement Wall: step 5, image 2 of 2
    • Wet the sponge and begin slightly tapping the newly plastered area.
    • Moisten the area until the entire boxed in area is damp.
  6. How to Repair Cracks in a Cement Wall: step 6, image 1 of 3 How to Repair Cracks in a Cement Wall: step 6, image 2 of 3 How to Repair Cracks in a Cement Wall: step 6, image 3 of 3
    • Add stucco finish with the tile trowel.
    • Once the cemented area is covered with the stucco finish, take the foam plastering trowel and spread stucco finish to the edges of the tape.
    • If the trowel is too dry to spread the finish, moisten it with the water from earlier.
    • Blend the finish into the surrounding tape.
  7. How to Repair Cracks in a Cement Wall: step 7, image 1 of 1
    • Remove the tape and blend areas that may not match.
    • Allow time for the finish to dry and the wall will be restored to crack-free.
Enjoy your repaired concrete fence wall. These steps can also be used on any other concrete surfaces that have cracks.
Mariah Gonzales
164 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 86
All Time: 4,163
