How to Repair a Cracked Mirror
  1. How to Repair a Cracked Mirror, How to Repair a Cracked Mirror: step 1, image 1 of 1
    • Clean the mirror with soap and water.
  2. How to Repair a Cracked Mirror: step 2, image 1 of 3 How to Repair a Cracked Mirror: step 2, image 2 of 3 How to Repair a Cracked Mirror: step 2, image 3 of 3
    • Remove the adhesive backing of the stabilizer film.
    • Press the stabilizer film over the crack.
    • Use your fingers to smooth out the stabilizer film.
  3. How to Repair a Cracked Mirror: step 3, image 1 of 1
    • Fill the syringe with epoxy resin.
  4. How to Repair a Cracked Mirror: step 4, image 1 of 2 How to Repair a Cracked Mirror: step 4, image 2 of 2
    • Insert the tip of the syringe through the stabilizer film.
    • Push down the plunger to fill the crack with resin.
  5. How to Repair a Cracked Mirror: step 5, image 1 of 1
    • Set a timer for 20 mins and wait for the resin to harden.
  6. How to Repair a Cracked Mirror: step 6, image 1 of 1
    • Peel off the stabilizer film.
  7. How to Repair a Cracked Mirror: step 7, image 1 of 2 How to Repair a Cracked Mirror: step 7, image 2 of 2
    • Add a drop of resin over the crack.
    • Cover the resin with the curing film.
  8. How to Repair a Cracked Mirror: step 8, image 1 of 1
    • Set a timer for 1 hour and wait for the resin to cure.
  9. How to Repair a Cracked Mirror: step 9, image 1 of 2 How to Repair a Cracked Mirror: step 9, image 2 of 2
    • Remove the curing film.
    • Scrape away any excess resin using the razor blade.
    • Use caution when handling the razor blade as you do not want to cut yourself during the process.
  10. How to Repair a Cracked Mirror: step 10, image 1 of 1
    • Clean the area with glass cleaner.
Marriam Shaikh
181 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 58
Past 30 Days: 262
All Time: 577
