How to Repair a Warped Sterling Silver Ring
  1. How to Repair a Warped Sterling Silver Ring, How to Repair a Warped Sterling Silver Ring: step 1, image 1 of 1
    • Fill a cooking pot halfway full with water.
  2. How to Repair a Warped Sterling Silver Ring: step 2, image 1 of 2 How to Repair a Warped Sterling Silver Ring: step 2, image 2 of 2
    • Place the pot with water on the stove.
    • Turn the stove burner on to medium heat.
    • Using a stove can cause burns. Be sure to watch where you place your hands or if there are people around who may accidentally be burned.
    • Gas stoves can expose excess gas into your house when they are not lit properly and can lead to unconsciousness or serious injuries.
  3. How to Repair a Warped Sterling Silver Ring: step 3, image 1 of 2 How to Repair a Warped Sterling Silver Ring: step 3, image 2 of 2
    • Boil the water until it starts steaming.
    • Use tongs to hold the ring and place it in the steaming water.
    • Boiling water can cause burn injuries when splashed onto skin.
  4. How to Repair a Warped Sterling Silver Ring: step 4, image 1 of 1
    • Release the grip on the ring, and let the ring sit at the bottom of the pot.
    • Remove the tongs from the pot and set them aside.
    • Boil the ring in the water for 5 minutes.
  5. How to Repair a Warped Sterling Silver Ring: step 5, image 1 of 2 How to Repair a Warped Sterling Silver Ring: step 5, image 2 of 2
    • After 5 minutes, remove the ring from the boiling water using tongs.
    • Place the ring on a paper towel for 5 minutes to cool the metal.
    • The metal of the ring will be hot and can burn your skin.
  6. How to Repair a Warped Sterling Silver Ring: step 6, image 1 of 3 How to Repair a Warped Sterling Silver Ring: step 6, image 2 of 3 How to Repair a Warped Sterling Silver Ring: step 6, image 3 of 3
    • Place the warped ring on a metal mandrel.
    • Pull the ring down the mandrel to the desired ring size.
    • Our desired ring size was a size 8.
  7. How to Repair a Warped Sterling Silver Ring: step 7, image 1 of 3 How to Repair a Warped Sterling Silver Ring: step 7, image 2 of 3 How to Repair a Warped Sterling Silver Ring: step 7, image 3 of 3
    • Use a rubber mallet to gently pound the ring band until it is round again.
    • Be careful with your fingers while using the mallet.
    • Rotate the ring to check that it is round and smooth.
    • Pull the ring off the mandrel.
  8. How to Repair a Warped Sterling Silver Ring: step 8, image 1 of 1
    • Place the restored ring on your desired finger.
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 40
All Time: 173
