How to Replace Keys on a Keyboard
  1. How to Replace Keys on a Keyboard, Individual Keys: step 1, image 1 of 2 How to Replace Keys on a Keyboard, Individual Keys: step 1, image 2 of 2
    • Loosen the key by prying all four corners gently with your spudger.
    • Make sure your keyboard is unplugged before performing any of these steps.
  2. How to Replace Keys on a Keyboard: step 2, image 1 of 2 How to Replace Keys on a Keyboard: step 2, image 2 of 2
    • Wedge the tip of the spudger under the bottom of the key and carefully lift up until the key pops loose.
    • If the key will not come out, or seems like too much force is needed, try step one again.
  3. How to Replace Keys on a Keyboard: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to remove any contaminants that were preventing the key from being pressed down from the now open hole on your keyboard.
    • Do not to grab the actual button, as breaking that could damage your keyboard permanently.
  4. How to Replace Keys on a Keyboard: step 4, image 1 of 1
    • Clean your keys with compressed air by blowing around the removed key.
  5. How to Replace Keys on a Keyboard: step 5, image 1 of 2 How to Replace Keys on a Keyboard: step 5, image 2 of 2
    • Push in the clean keys until you hear a popping sound.
    • The keys should click in easily, so if you are having trouble try realigning the key with its hole.
    • If you removed multiple keys, make sure they are in their proper spot and orientation.
Congratulations! You now have a keyboard with fully functional keys!
6 other people completed this guide.
Cooper
457 Reputation
2 Guides authored
Cal Poly, Team 24-6, Green Winter 2015 Member of Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Members
15 Guides authored
2 Comments
This is How to CLEAN keys, not replace them. Duh.
Mike Miller - Reply
I came looking for how to replace the problematic ones like + on numpad :<
Eskalina Cvrnkalikova - Reply
Past 24 Hours: 6
Past 7 Days: 49
Past 30 Days: 240
All Time: 16,874
