How to Replace T-fal Avante T24-B Toaster Lever
  1. How to Replace T-fal Avante T24-B Toaster Lever, T-fal Avante T24-B Toaster Lever: step 1, image 1 of 1
    • Make sure the toaster is unplugged before beginning.
  2. How to Replace T-fal Avante T24-B Toaster Lever: step 2, image 1 of 3 How to Replace T-fal Avante T24-B Toaster Lever: step 2, image 2 of 3 How to Replace T-fal Avante T24-B Toaster Lever: step 2, image 3 of 3
    • Remove the snap-on buttons from the front of the toaster.
    • They can be removed by pulling with your hands or gently prying with a flat tool.
  3. How to Replace T-fal Avante T24-B Toaster Lever: step 3, image 1 of 3 How to Replace T-fal Avante T24-B Toaster Lever: step 3, image 2 of 3 How to Replace T-fal Avante T24-B Toaster Lever: step 3, image 3 of 3
    • Flip the toaster so that you can see its underside.
    • Remove the seven 20 mm Torx T3 screws from the bottom of the toaster.
  4. How to Replace T-fal Avante T24-B Toaster Lever: step 4, image 1 of 2 How to Replace T-fal Avante T24-B Toaster Lever: step 4, image 2 of 2
    • Turn the toaster so that you can access the back of the toaster
    • Remove the 3 15 mm Torx T3 screws from the back of the toaster.
  5. How to Replace T-fal Avante T24-B Toaster Lever: step 5, image 1 of 2 How to Replace T-fal Avante T24-B Toaster Lever: step 5, image 2 of 2
    • Pull off the toaster casing.
  6. How to Replace T-fal Avante T24-B Toaster Lever: step 6, image 1 of 2 How to Replace T-fal Avante T24-B Toaster Lever: step 6, image 2 of 2
    • Unplug the casing so that it does not get in your way.
    • Unplug both wires connecting the casing to the internals of the toaster.
  7. How to Replace T-fal Avante T24-B Toaster Lever: step 7, image 1 of 3 How to Replace T-fal Avante T24-B Toaster Lever: step 7, image 2 of 3 How to Replace T-fal Avante T24-B Toaster Lever: step 7, image 3 of 3
    • Pry both sides of the broken lever at the front of the toaster away and remove it.
  8. How to Replace T-fal Avante T24-B Toaster Lever: step 8, image 1 of 3 How to Replace T-fal Avante T24-B Toaster Lever: step 8, image 2 of 3 How to Replace T-fal Avante T24-B Toaster Lever: step 8, image 3 of 3
    • Snap the replacement lever into place.
    • Attach one side first, then snap the other side on to fully attach the lever.
Cameron Johnson
157 Reputation
1 Guide authored
2 Comments
Thank you so much!
S J - Reply
where do you get the replacement lever ?
Francois Rehel - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 40
All Time: 522
