How to Replace a Coffee Tabletop Glass
  1. How to Replace a Coffee Tabletop Glass, Coffee Table Glass: step 1, image 1 of 2 How to Replace a Coffee Tabletop Glass, Coffee Table Glass: step 1, image 2 of 2
    • Flip the coffee table base upside down on an empty area.
  2. How to Replace a Coffee Tabletop Glass: step 2, image 1 of 1
    • Use a cleaning spray to clean the surface of the glass table.
    • Use gloves while cleaning the table. The glass cleaner spray may contain toxic chemicals.
  3. How to Replace a Coffee Tabletop Glass: step 3, image 1 of 2 How to Replace a Coffee Tabletop Glass: step 3, image 2 of 2
    • Use a Phillips #2 screwdriver to remove one 1/4 in.-20 x 1-1/2 in. socket cap screw from the side of the glass.
    • Repeat the process for the other 1/4 in.-20 x 1-1/2 in. socket cap screw.
    • The appearance of this screw may differ from table to table, but the procedure remains the same. Use the appropriate screwdriver to open the screws.
  4. How to Replace a Coffee Tabletop Glass: step 4, image 1 of 2 How to Replace a Coffee Tabletop Glass: step 4, image 2 of 2
    • Remove the coffee table legs piece by piece.
  5. How to Replace a Coffee Tabletop Glass: step 5, image 1 of 1
    • Remove the glass.
    • Remember that glass can be shattered or partially damaged. Use gloves to avoid possible cuts.
  6. How to Replace a Coffee Tabletop Glass: step 6, image 1 of 1
    • Replace the broken/ damaged glass with the new one.
Jasrin Kaur
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 76
All Time: 2,378
