How to Replace the Adhesive for Your Google Pixel 6a
  1. How to Replace the Adhesive for Your Google Pixel 6a, Clean the frame: step 1, image 1 of 3 How to Replace the Adhesive for Your Google Pixel 6a, Clean the frame: step 1, image 2 of 3 How to Replace the Adhesive for Your Google Pixel 6a, Clean the frame: step 1, image 3 of 3
    Tool used on this step:
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • Any residual adhesive or debris on the frame will prevent your screen from sealing properly.
    • Use the flat end of your spudger to scrape off as much adhesive from the frame as you can.
    • Use tweezers or your fingers to peel and remove any remaining adhesive.
    • Clean the perimeter of the frame with a small amount of highly-concentrated isopropyl alcohol (over 90%) and a lint-free or microfiber cloth.
  2. How to Replace the Adhesive for Your Google Pixel 6a, Clean the screen: step 2, image 1 of 3 How to Replace the Adhesive for Your Google Pixel 6a, Clean the screen: step 2, image 2 of 3 How to Replace the Adhesive for Your Google Pixel 6a, Clean the screen: step 2, image 3 of 3
    • If you're reusing your screen, clean it as you did for the frame.
  3. How to Replace the Adhesive for Your Google Pixel 6a, Orient the adhesive: step 3, image 1 of 2 How to Replace the Adhesive for Your Google Pixel 6a, Orient the adhesive: step 3, image 2 of 2
    • Before removing any liners, position the adhesive with the clear liner facing down over the frame to find the proper orientation.
    • Use features such as the upper loudspeaker cutout and conductive tape to orient the adhesive.
  4. How to Replace the Adhesive for Your Google Pixel 6a, Remove the adhesive liner: step 4, image 1 of 1
    • Peel the clear liner off of the adhesive.
  5. How to Replace the Adhesive for Your Google Pixel 6a, Apply the adhesive: step 5, image 1 of 3 How to Replace the Adhesive for Your Google Pixel 6a, Apply the adhesive: step 5, image 2 of 3 How to Replace the Adhesive for Your Google Pixel 6a, Apply the adhesive: step 5, image 3 of 3
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lay the adhesive onto the frame, starting with the bottom or top edge. Make small corrections as you go.
  6. How to Replace the Adhesive for Your Google Pixel 6a: step 6, image 1 of 2 How to Replace the Adhesive for Your Google Pixel 6a: step 6, image 2 of 2
    • Use a spudger or your fingers to press along the perimeter of the adhesive and adhere it to the frame.
  7. How to Replace the Adhesive for Your Google Pixel 6a, Remove the liners: step 7, image 1 of 3 How to Replace the Adhesive for Your Google Pixel 6a, Remove the liners: step 7, image 2 of 3 How to Replace the Adhesive for Your Google Pixel 6a, Remove the liners: step 7, image 3 of 3
    • Grab the pull tab on the upper right of the frame and peel off the main liner.
  8. How to Replace the Adhesive for Your Google Pixel 6a, Check for small liners: step 8, image 1 of 1
    • Check the front-facing camera hole on the replacement screen and remove any remaining protective liners in it.
    • Check the sensor cutout on the replacement screen and remove any remaining protector liners in it.
  9. How to Replace the Adhesive for Your Google Pixel 6a, Continue reassembly: step 9, image 1 of 1
    • Return to your phone's guide and continue reassembly.
    • Remember to reinstall the display cable bracket.
    • Finish this guide when your screen is installed and you're ready to seal the phone up.
  10. How to Replace the Adhesive for Your Google Pixel 6a, Remove the final liner: step 10, image 1 of 3 How to Replace the Adhesive for Your Google Pixel 6a, Remove the final liner: step 10, image 2 of 3 How to Replace the Adhesive for Your Google Pixel 6a, Remove the final liner: step 10, image 3 of 3
    • Grab the pull tab on the bottom edge of the frame and peel off the remaining liner.
  11. How to Replace the Adhesive for Your Google Pixel 6a, Install the screen: step 11, image 1 of 2 How to Replace the Adhesive for Your Google Pixel 6a, Install the screen: step 11, image 2 of 2
    • Flip the screen over and lay it onto the frame.
    • Press along the perimeter of the screen to secure it.
Finish Line
90 other people completed this guide.
Alex Diaz-Kokaisl
125,037 Reputation
582 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
10 Comments
Yup. That worked, Don't rush it, and get a proper suction cup, but i have a perfectly repaired 6a, very happy, and thank you
Eoin Fleming - Reply
Great advice, but there must be something I'm missing. Now my phone can't show the screen
icanwecanyoucan - Reply
Will this provide the same water resistance as the original screen?
Noam Etten - Reply
Depends on how well you seat the adhesive, but generally speaking, it's very hard to get to the same level of water resistance. It will probably be somewhat resistant.
Water resistance should be treated as an additional protection, not as a feature. Do not submerge your electronic device in water by purpose. (even if it's factory new)
Gabriele Turelli (CappyT) -
You guys are awesome, you know that? After almost 2 hours of work, everything works again. Thanks a lot. Greetings from Belgium
DaMuf84 - Reply
Past 24 Hours: 24
Past 7 Days: 263
Past 30 Days: 1,164
All Time: 22,819
