How to Replace the Screen Adhesive on Your Switch Lite
  1. How to Replace the Screen Adhesive on Your Switch Lite, Apply isopropyl alcohol: step 1, image 1 of 3 How to Replace the Screen Adhesive on Your Switch Lite, Apply isopropyl alcohol: step 1, image 2 of 3 How to Replace the Screen Adhesive on Your Switch Lite, Apply isopropyl alcohol: step 1, image 3 of 3
    • Apply high concentration (90% or greater) isopropyl alcohol to the old screen adhesive on the frame.
    • Wait one minute to allow the alcohol to penetrate the adhesive.
  2. How to Replace the Screen Adhesive on Your Switch Lite, Remove the old adhesive: step 2, image 1 of 3 How to Replace the Screen Adhesive on Your Switch Lite, Remove the old adhesive: step 2, image 2 of 3 How to Replace the Screen Adhesive on Your Switch Lite, Remove the old adhesive: step 2, image 3 of 3
    Tool used on this step:
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • Use the flat end of a spudger to scrape all the old adhesive from the frame.
    • Use a microfiber cloth to clean the frame.
  3. How to Replace the Screen Adhesive on Your Switch Lite, Measure and cut the adhesive: step 3, image 1 of 3 How to Replace the Screen Adhesive on Your Switch Lite, Measure and cut the adhesive: step 3, image 2 of 3 How to Replace the Screen Adhesive on Your Switch Lite, Measure and cut the adhesive: step 3, image 3 of 3
    Tesa 61395 Tape
    $5.99
    Buy
    • Measure and cut four strips of 2 mm‑wide Tesa tape for the back of the screen:
    • Two strips for the long edges
    • Two strips for the short edges
    • You can use other adhesives, but make sure the strips are no wider than 3 mm.
  4. How to Replace the Screen Adhesive on Your Switch Lite, Apply the adhesive: step 4, image 1 of 3 How to Replace the Screen Adhesive on Your Switch Lite, Apply the adhesive: step 4, image 2 of 3 How to Replace the Screen Adhesive on Your Switch Lite, Apply the adhesive: step 4, image 3 of 3
    • Apply the adhesive strips sticky side down to the back of the screen, making sure the tape goes under the screen and digitizer cables.
  5. How to Replace the Screen Adhesive on Your Switch Lite: step 5, image 1 of 2 How to Replace the Screen Adhesive on Your Switch Lite: step 5, image 2 of 2
    Buy
    • Use tweezers to remove the liners from the adhesive strips.
  6. How to Replace the Screen Adhesive on Your Switch Lite, Orient the screen: step 6, image 1 of 1
    • Orient the screen before adhering it to the frame:
    • The right edge of the screen has two wide cables that line up with the action buttons.
    • The left edge of the screen has one small cable that lines up with the directional pad.
  7. How to Replace the Screen Adhesive on Your Switch Lite, Place the screen on the frame: step 7, image 1 of 2 How to Replace the Screen Adhesive on Your Switch Lite, Place the screen on the frame: step 7, image 2 of 2
    • Lay the right edge of the screen on the frame at a downward angle, making sure its cables go under the frame.
  8. How to Replace the Screen Adhesive on Your Switch Lite: step 8, image 1 of 2 How to Replace the Screen Adhesive on Your Switch Lite: step 8, image 2 of 2
    • Lay the left edge of the screen onto the frame, making sure the small cable goes under the frame.
  9. How to Replace the Screen Adhesive on Your Switch Lite, Secure the new screen: step 9, image 1 of 2 How to Replace the Screen Adhesive on Your Switch Lite, Secure the new screen: step 9, image 2 of 2
    • Press down firmly around the perimeter of the screen to adhere it to the frame.
    • Make sure the top of the screen is flush with the frame.
Finish Line
7 other people completed this guide.
Spencer Day
58,892 Reputation
430 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,624 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 42
Past 30 Days: 249
All Time: 4,513
