How to Restore An Expo Marker
  1. How to Restore  An Expo Marker, How to Restore  An Expo Marker: step 1, image 1 of 1
    • Collect all of the markers you want to restore.
    • Obtain isopropyl alcohol (rubbing alcohol) or vinegar.
  2. How to Restore  An Expo Marker: step 2, image 1 of 1
    • Pour a small amount of either alcohol or vinegar into a small bowl, using enough to cover the tip of the markers.
    • Soak the tip of the markers in the alcohol or vinegar until the ink comes out of the tip of the marker.
    • In some cases, you will see the ink of the marker swirl out.
  3. How to Restore  An Expo Marker: step 3, image 1 of 2 How to Restore  An Expo Marker: step 3, image 2 of 2
    • Place the cap back on the marker.
    • Let the marker sit tip side up for at least 24 hours. The alcohol should penetrate inside the tip of the marker.
  4. How to Restore  An Expo Marker: step 4, image 1 of 1
    • Your marker should be good to go.
    • If your marker is not functioning properly, it may be a sign that your marker dried out completely.
3 other people completed this guide.
Alexus A Carpenter
154 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 16
Past 7 Days: 165
Past 30 Days: 767
All Time: 37,921
