How to Restore and Season a Cast Iron Pan
  1. How to Restore and Season a Cast Iron Pan, How to Restore and Season a Cast Iron Pan: step 1, image 1 of 1
    • Soak your pan in a roughly 50/50 mix of distilled white vinegar and water for about an hour.
    • You can wait longer if the rust is particularly bad.
  2. How to Restore and Season a Cast Iron Pan: step 2, image 1 of 1
    • Remove the pan from the vinegar solution.
    • Immediately apply baking soda to the pan to neutralize the acidity of the vinegar.
    • Start to wipe away the rust with steel wool.
  3. How to Restore and Season a Cast Iron Pan: step 3, image 1 of 1
    • Scour your pan inside and out with steel wool until either the rust or the white heat-damaged area appears black.
  4. How to Restore and Season a Cast Iron Pan: step 4, image 1 of 2 How to Restore and Season a Cast Iron Pan: step 4, image 2 of 2
    • Thoroughly dry your pan and place it over medium flame or in a 350 degrees Fahrenheit oven for 5 to ten minutes to allow it to completely dry.
  5. How to Restore and Season a Cast Iron Pan: step 5, image 1 of 3 How to Restore and Season a Cast Iron Pan: step 5, image 2 of 3 How to Restore and Season a Cast Iron Pan: step 5, image 3 of 3
    • Apply a generous amount of oil to the pan and rub it all over with a paper towel, making sure to hit every nook and cranny.
    • This process will remove the thin film of rust left by step 4.
  6. How to Restore and Season a Cast Iron Pan: step 6, image 1 of 1
    • Use a clean paper towel to thoroughly wipe off the pan.
  7. How to Restore and Season a Cast Iron Pan: step 7, image 1 of 2 How to Restore and Season a Cast Iron Pan: step 7, image 2 of 2
    • Repeat steps 5 and 6.
    • Place the pan upside down in an oven and turn it up to 500 degrees Fahrenheit or as high as it will go.
    • Once the oven reaches that temperature leave the pan in it for one hour.
  8. How to Restore and Season a Cast Iron Pan: step 8, image 1 of 1
    • Turn off the heat.
    • Allow the pan to cool naturally in the oven.
  9. How to Restore and Season a Cast Iron Pan: step 9, image 1 of 1
    • Your pan is now seasoned.
    • You may repeat steps 5-8 up to 6 times for higher quality results.
You’re all done!
Mikhail Keyes
219 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 39
All Time: 1,141
