How to Restring a Badminton Racquet
  1. How to Restring a Badminton Racquet, How to Restring a Badminton Racquet: step 1, image 1 of 1
    • Insert one end of the string through the hole at the bottom of the racquet closest to the shaft and drag it straight up to the corresponding hole at the top of the raquet.
  2. How to Restring a Badminton Racquet: step 2, image 1 of 1
    • Loop the string through the top two holes and drag it back down to the hole on the opposite side of the shaft you started from.
    • Make sure the excess string is evenly divided so that each side has the same amount.
  3. How to Restring a Badminton Racquet: step 3, image 1 of 2 How to Restring a Badminton Racquet: step 3, image 2 of 2
    • Continue to string straight up and down one side of the racquet until you reach the area of the racquet that naturally begins to curve.
  4. How to Restring a Badminton Racquet: step 4, image 1 of 1
    • When you're done stringing, there should be some leftover string at the top.
    • If there is not enough to properly tie off, pull on the strands in order to create slack in the line.
  5. How to Restring a Badminton Racquet: step 5, image 1 of 2 How to Restring a Badminton Racquet: step 5, image 2 of 2
    • Use your fingers to make a knot (you may need to make two knots on top of each other so the string can't slide back through the hole).
    • Pull on each strand, beginning with the outermost strand with the knot, and move towards the middle so that the string tightens up and becomes taut.
  6. How to Restring a Badminton Racquet: step 6, image 1 of 1
    • Perform the same steps of stringing on the other side of the racquet and make a knot at the top. Make sure to pull very tightly to reduce slack in the string and create the knot as close to the hole in the racquet as possible.
    • Use the pliers to help hold the strings taught while tying the second knot. The pliers can also be used to slide the knot closer to the hole in the racquet if you have trouble making a small, close knot with your fingers.
  7. How to Restring a Badminton Racquet: step 7, image 1 of 1
    • To begin the horizontal stringing, tie the second string onto the racquet frame. Start at the fourth hole over from the base and make a knot with your fingers on the inside of the frame.
    • Loop the string back inwards through the seventh hole from the base.
  8. How to Restring a Badminton Racquet: step 8, image 1 of 1
    • When stringing the horizontal strands, you must weave over and under each vertical strand with the new string while continuing to pull the string tight.
  9. How to Restring a Badminton Racquet: step 9, image 1 of 1
    • Thread the horizontal strand straight across and through the hole opposite the one you started at. Loop back into the next hole up the side of the racquet.
    • For the second row, string under-over instead of over-under so that the horizontal strands alternate being on top of or underneath each vertical strand.
  10. How to Restring a Badminton Racquet: step 10, image 1 of 1
    • With each additional row you string up the racquet, switch from over-under to under-over so that every other horizontal string follows the same pattern.
    • A weave pattern should start to form and your racquet should begin to resemble the image.
  11. How to Restring a Badminton Racquet: step 11, image 1 of 1
    • At the end of the strand (right when the racquet naturally begins to curve), pull the strings tight. You may need to pull on each strand from the base up to get rid of any slack in the string. Make sure the tension in the strings is very high and there is little give when you push down on the strings with your hand.
    • Tie a knot in the string on the outside of the racquet. Make the knot very close to the racquet for best tension, pliers can help slide the knot down to the frame. More than one knot may be necessary to prevent the string from sliding back through the hole.
  12. How to Restring a Badminton Racquet: step 12, image 1 of 1
    • Cut off all the excess string, leaving some space after the knots.
  13. How to Restring a Badminton Racquet: step 13, image 1 of 1
    • Your final product is ready. The strings should not move much when you gently push down on them with your hand.
    • If they are loose, consider tightening the strings by pulling out slack strand by strand before retying a knot.
Finish Line
10 other people completed this guide.
Sabina
434 Reputation
1 Guide authored
4 Comments
Very Simple and easily understandable guideline.
I request Sabina to please include guidelines on automatic stringing Badminton machine(Siboasi)with steps and images.
If possible please send me on my email address(dvc870621@gmail.com).
Thanks
Deepak Chaudhari
Deepak Chaudhari - Reply
Would only recommend this method for very cheap rackets, but at that price point, it is very possible that the cost of the string will exceed the price of a new racket.
Never tie off the on the outside of the racket as this leads to increased stress on the frame.
Michael Lin - Reply
Did this for the first time on an older racket and I am impressed, had to experiment a bit with different tie of knots but got there in the end. The final tension isn't super tight but I have ideas to improve this in the future attempts, but still quite happy for the first attempt. Just a note that, it will require ¬10m length of string to fully string a racket. Thanks.
Jeff J - Reply
jamais vu une telle merde, qui est capable de corder une raquette aussi mal ? C est une honte.
Sylvain Petitjean - Reply
Past 24 Hours: 11
Past 7 Days: 105
Past 30 Days: 528
All Time: 37,629
