How to Test the Defrost Heater on Your LG Refrigerator
  1. How to Test the Defrost Heater on Your LG Refrigerator, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. How to Test the Defrost Heater on Your LG Refrigerator, Open the freezer door: step 2, image 1 of 2 How to Test the Defrost Heater on Your LG Refrigerator, Open the freezer door: step 2, image 2 of 2
    • Pull open the freezer door fully.
  3. How to Test the Defrost Heater on Your LG Refrigerator, Remove the drawer and bin: step 3, image 1 of 3 How to Test the Defrost Heater on Your LG Refrigerator, Remove the drawer and bin: step 3, image 2 of 3 How to Test the Defrost Heater on Your LG Refrigerator, Remove the drawer and bin: step 3, image 3 of 3
    • Lift and remove the upper pull-out drawer.
    • Lift and remove the main drawer bin.
  4. How to Test the Defrost Heater on Your LG Refrigerator, Remove the drawer rail covers: step 4, image 1 of 3 How to Test the Defrost Heater on Your LG Refrigerator, Remove the drawer rail covers: step 4, image 2 of 3 How to Test the Defrost Heater on Your LG Refrigerator, Remove the drawer rail covers: step 4, image 3 of 3
    • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
    • Lift the cover off of the rail and remove it.
    • Repeat this procedure for the left drawer rail cover.
  5. How to Test the Defrost Heater on Your LG Refrigerator, Reassembly notes: step 5, image 1 of 2 How to Test the Defrost Heater on Your LG Refrigerator, Reassembly notes: step 5, image 2 of 2
    • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
    • Hold the drawer rail cover flush against the side of the drawer rail.
    • You should feel the locking tabs protruding.
    • Push the rail cover straight downward to install. It should click into place.
  6. How to Test the Defrost Heater on Your LG Refrigerator, Remove the drawer: step 6, image 1 of 2 How to Test the Defrost Heater on Your LG Refrigerator, Remove the drawer: step 6, image 2 of 2
    • Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
  7. How to Test the Defrost Heater on Your LG Refrigerator: step 7, image 1 of 3 How to Test the Defrost Heater on Your LG Refrigerator: step 7, image 2 of 3 How to Test the Defrost Heater on Your LG Refrigerator: step 7, image 3 of 3
    • Lift the front of the drawer up.
    • Pull the drawer toward you to release the drawer from the drawer slides.
    • Remove the freezer drawer.
  8. How to Test the Defrost Heater on Your LG Refrigerator, Release the drawer slides: step 8, image 1 of 1
    • Use a Phillips screwdriver to remove the screws securing both left drawer slides.
  9. How to Test the Defrost Heater on Your LG Refrigerator, Remove the upper left drawer slide: step 9, image 1 of 2 How to Test the Defrost Heater on Your LG Refrigerator, Remove the upper left drawer slide: step 9, image 2 of 2
    • Pull the upper left drawer slide slightly towards you to release the locking tab at the rear.
    • Remove the upper left drawer slide.
  10. How to Test the Defrost Heater on Your LG Refrigerator, Release lower left drawer slide and reposition it: step 10, image 1 of 3 How to Test the Defrost Heater on Your LG Refrigerator, Release lower left drawer slide and reposition it: step 10, image 2 of 3 How to Test the Defrost Heater on Your LG Refrigerator, Release lower left drawer slide and reposition it: step 10, image 3 of 3
    • Pull the lower left drawer slide slightly toward you to release the locking tab at the rear.
    • Reposition the lower left drawer slide to gain access to the door switch connector.
  11. How to Test the Defrost Heater on Your LG Refrigerator, Disconnect the drawer switch and remove the lower slide: step 11, image 1 of 3 How to Test the Defrost Heater on Your LG Refrigerator, Disconnect the drawer switch and remove the lower slide: step 11, image 2 of 3 How to Test the Defrost Heater on Your LG Refrigerator, Disconnect the drawer switch and remove the lower slide: step 11, image 3 of 3
    • Squeeze the door switch connector to release it.
    • Pull the door switch connector down to disconnect it.
    • Remove the lower left drawer slide.
    • If you are removing the freezer evaporator cover, likely only the left-hand slides may need to be removed. In some cases you will need to repeat the previous three steps to remove the right slides as well.
  12. How to Test the Defrost Heater on Your LG Refrigerator, Release the ice maker: step 12, image 1 of 1
    • Use a Phillips screwdriver to remove the screws securing the ice maker to the top of the freezer compartment.
  13. How to Test the Defrost Heater on Your LG Refrigerator: step 13, image 1 of 3 How to Test the Defrost Heater on Your LG Refrigerator: step 13, image 2 of 3 How to Test the Defrost Heater on Your LG Refrigerator: step 13, image 3 of 3
    • Insert a flat-blade screwdriver into the slot located on the right edge of the ice maker.
    • Pry outward with the screwdriver to release the locking tab securing the ice maker to the fridge.
    • When the tab releases, pull the right front corner of the ice maker down.
  14. How to Test the Defrost Heater on Your LG Refrigerator: step 14, image 1 of 1
    • Repeat the previous operation on the left side of the ice maker to release it.
  15. How to Test the Defrost Heater on Your LG Refrigerator: step 15, image 1 of 3 How to Test the Defrost Heater on Your LG Refrigerator: step 15, image 2 of 3 How to Test the Defrost Heater on Your LG Refrigerator: step 15, image 3 of 3
    • Grasp the front edge of the ice maker and pull it towards you.
    • Lower the ice maker.
  16. How to Test the Defrost Heater on Your LG Refrigerator, Disconnect and remove the ice maker: step 16, image 1 of 3 How to Test the Defrost Heater on Your LG Refrigerator, Disconnect and remove the ice maker: step 16, image 2 of 3 How to Test the Defrost Heater on Your LG Refrigerator, Disconnect and remove the ice maker: step 16, image 3 of 3
    • Squeeze the ice maker connector to release it and pull it straight out to disconnect it.
    • Remove the ice maker.
  17. How to Test the Defrost Heater on Your LG Refrigerator, Remove air return cover: step 17, image 1 of 3 How to Test the Defrost Heater on Your LG Refrigerator, Remove air return cover: step 17, image 2 of 3 How to Test the Defrost Heater on Your LG Refrigerator, Remove air return cover: step 17, image 3 of 3
    • Pinch the rear portion of the air return cover to release it from the freezer wall.
    • Pull the air return cover outward and remove it.
  18. How to Test the Defrost Heater on Your LG Refrigerator, Unfasten the evaporator cover: step 18, image 1 of 1
    • Use a Philips screwdriver to remove the screw (or screws) securing the evaporator cover.
  19. How to Test the Defrost Heater on Your LG Refrigerator, Reposition the evaporator cover: step 19, image 1 of 2 How to Test the Defrost Heater on Your LG Refrigerator, Reposition the evaporator cover: step 19, image 2 of 2
    • Don't try to remove the evaporator cover fully, as It is still connected to the fridge with a number of wires.
    • Grasp the evaporator cover by the air vent openings and pull the top edge toward you.
  20. How to Test the Defrost Heater on Your LG Refrigerator: step 20, image 1 of 3 How to Test the Defrost Heater on Your LG Refrigerator: step 20, image 2 of 3 How to Test the Defrost Heater on Your LG Refrigerator: step 20, image 3 of 3
    • Lift the evaporator cover slightly to release the tabs at the lower edge.
    • Swing the left edge of the evaporator cover toward you and lower it.
  21. How to Test the Defrost Heater on Your LG Refrigerator, Disconnect the evaporator cover: step 21, image 1 of 3 How to Test the Defrost Heater on Your LG Refrigerator, Disconnect the evaporator cover: step 21, image 2 of 3 How to Test the Defrost Heater on Your LG Refrigerator, Disconnect the evaporator cover: step 21, image 3 of 3
    • Disconnect the electrical connections in the upper left corner of the freezer.
    • Make a note of the locations of the connections for re-installation.
  22. How to Test the Defrost Heater on Your LG Refrigerator: step 22, image 1 of 3 How to Test the Defrost Heater on Your LG Refrigerator: step 22, image 2 of 3 How to Test the Defrost Heater on Your LG Refrigerator: step 22, image 3 of 3
    • Swing the left edge of the evaporator cover further toward you to access the connections in the upper right corner.
    • Squeeze and pull the connector to disconnect the thermistor mounted in the evaporator cover.
  23. How to Test the Defrost Heater on Your LG Refrigerator, Remove the evaporator cover: step 23, image 1 of 2 How to Test the Defrost Heater on Your LG Refrigerator, Remove the evaporator cover: step 23, image 2 of 2
    • Remove the evaporator cover.
  24. How to Test the Defrost Heater on Your LG Refrigerator, Trace the defrost heater wires: step 24, image 1 of 2 How to Test the Defrost Heater on Your LG Refrigerator, Trace the defrost heater wires: step 24, image 2 of 2
    • If you have a multimeter, you can test the defrost heater for proper resistance.
    • Set the multimeter to the ohm setting.
    • Trace the two wires of the defrost heater to its connector. Disconnect the connector by squeezing the tab and pulling it straight out.
    • In this case, the defrost fuse and the heater are wired in series, so your test will also show if the fuse is ok.
    • In the photos here, the orange wires are for the defrost thermistor, not the defrost heater. The heater wires will usually be larger sized.
  25. How to Test the Defrost Heater on Your LG Refrigerator, Test the resistance of the heater: step 25, image 1 of 1
    • Measure the resistance between the two terminals on the connector.
    • The resistance should be between 30-42Ω.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
30,088 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 37
Past 30 Days: 164
All Time: 532
