How to fix stuck Joy-Con Triggers
  1. How to fix stuck Joy-Con Triggers, Removing Cover Screws: step 1, image 1 of 1
    • Using the Tri-Point Screwdriver, remove the 4 screws keeping the Joy-Con's shell together.
  2. How to fix stuck Joy-Con Triggers, Opening the Joy-Con: step 2, image 1 of 1
    • Lift the shell to reveal the internals of the Joy-Con
    • If you are fixing the opposite-side Joy-Con, it will appear to be a mirror image
  3. How to fix stuck Joy-Con Triggers, Locate the Button: step 3, image 1 of 1
    • Locate the ZR or ZL Button inside the Joy-Con Controller
  4. How to fix stuck Joy-Con Triggers, Positioning the Button: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to lift the ZL button, then put it back into it's correct position
    • Put the button in a position where clicking is possible
  5. How to fix stuck Joy-Con Triggers, Place the Shell back on the Joy-Con: step 5, image 1 of 1
    • Using the Tri-Point screwdriver, put the 4 screws back into place.
Congratulations, you did it!
4 other people completed this guide.
Russell Repair Co.
2,135 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 12
Past 7 Days: 39
Past 30 Days: 205
All Time: 3,771
