Hyggly Percussive Massage Gun Battery Replacement
  1. Hyggly Percussive Massage Gun Battery Replacement, Battery: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the 4 rubber stoppers on the massage gun.
    • You can use tweezers for ease or take the hard way and use your screwdriver.
  2. Hyggly Percussive Massage Gun Battery Replacement: step 2, image 1 of 2 Hyggly Percussive Massage Gun Battery Replacement: step 2, image 2 of 2
    • Using the Phillips #00 screwdriver, unscrew the 1 Phillips head screw underneath the power button.
    • Using the Phillips #00 screwdriver, unscrew the 4 Phillips head screws under the rubber stopper.
  3. Hyggly Percussive Massage Gun Battery Replacement: step 3, image 1 of 2 Hyggly Percussive Massage Gun Battery Replacement: step 3, image 2 of 2
    • Twist and remove the circular black lid that houses the main circuit board.
    • Pull apart the main body of the massage gun. The gun should now be in three parts.
    • Detach the wires connected to the main circuit board.
    • Remember to write down which wire attaches where.
  4. Hyggly Percussive Massage Gun Battery Replacement: step 4, image 1 of 2 Hyggly Percussive Massage Gun Battery Replacement: step 4, image 2 of 2
    • Using the Phillips #00 screwdriver, unscrew the 4 Phillips head screws inside the main body of the massage gun.
    • Pry open the lid once the screws are removed.
  5. Hyggly Percussive Massage Gun Battery Replacement: step 5, image 1 of 2 Hyggly Percussive Massage Gun Battery Replacement: step 5, image 2 of 2
    • Remove the top cover from battery compartment.
    • Remove the rubber sleeve off the battery compartment.
  6. Hyggly Percussive Massage Gun Battery Replacement: step 6, image 1 of 2 Hyggly Percussive Massage Gun Battery Replacement: step 6, image 2 of 2
    • Remove the sticker off the bottom of the battery compartment near the power switch.
    • Using the Phillips #00 screwdriver, unscrew the 3 Phillips head screws around the power switch to access the inside of the battery compartment.
  7. Hyggly Percussive Massage Gun Battery Replacement: step 7, image 1 of 1
    • Remove the bottom lid of the battery compartment to reveal the second circuit board.
    • Detach the wires of the battery from the circuit board.
    • Remember to write down the positioning of the wires.
  8. Hyggly Percussive Massage Gun Battery Replacement: step 8, image 1 of 1
    • Pry open the battery compartment
  9. Hyggly Percussive Massage Gun Battery Replacement: step 9, image 1 of 2 Hyggly Percussive Massage Gun Battery Replacement: step 9, image 2 of 2
    • Remove the old battery to replace the new one.
Raj Patel
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 69
All Time: 264
