InFocus X2 Lamp Replacement
  1. InFocus X2 Lamp Replacement, Open the Lamp Door: step 1, image 1 of 3 InFocus X2 Lamp Replacement, Open the Lamp Door: step 1, image 2 of 3 InFocus X2 Lamp Replacement, Open the Lamp Door: step 1, image 3 of 3
    • Be sure that the projector is turned off, unplugged, and has cooled for at least 30 seconds.
    • Insert the Jimmy into one of the two notches on the lamp door's top edge.
    • Then use light force on the Jimmy to pry the latch away from the door.
    • If necessary, insert the Jimmy into the second latch and separate it from the projector.
    • Remove the door away from the projector by hand.
  2. InFocus X2 Lamp Replacement, Disconnect the Lamp: step 2, image 1 of 3 InFocus X2 Lamp Replacement, Disconnect the Lamp: step 2, image 2 of 3 InFocus X2 Lamp Replacement, Disconnect the Lamp: step 2, image 3 of 3
    • Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug.
    • Then pull the plug away from the projector.
  3. InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: step 3, image 1 of 3 InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: step 3, image 2 of 3 InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: step 3, image 3 of 3
    • Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
    • For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector. If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
  4. InFocus X2 Lamp Replacement, Remove the Old Lamp: step 4, image 1 of 1
    • Pull on the bottom plastic tab and remove the lamp by hand.
  5. InFocus X2 Lamp Replacement, Insert the New Lamp: step 5, image 1 of 1
    • Insert the replacement lamp into the projector.
Caution: The old bulb contains mercury. Please recycle it in a safe and appropriate manner. Look for your local recycling information at https://earth911.com/
Attached Documents
Paulina Duarte
553 Reputation
4 Guides authored
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 Member of UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G3
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 732
