Dell Inspiron 5100 PP07L CD Drive Replacement
  1. Dell Inspiron 5100 PP07L CD Drive Replacement, Keyboard: step 1, image 1 of 1
    • Remove battery
    • Open screen so that it lies flat.
  2. Dell Inspiron 5100 PP07L CD Drive Replacement: step 2, image 1 of 2 Dell Inspiron 5100 PP07L CD Drive Replacement: step 2, image 2 of 2
    • Starting from the right side of the hinge cover, use the flat end of the spudger to pry up the hinge cover and gently remove it.
  3. Dell Inspiron 5100 PP07L CD Drive Replacement: step 3, image 1 of 2 Dell Inspiron 5100 PP07L CD Drive Replacement: step 3, image 2 of 2
    • Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard.
  4. Dell Inspiron 5100 PP07L CD Drive Replacement: step 4, image 1 of 1
    • Lift keyboard and detach the interface connector.
    • Take extra care when removing and handling the keyboard. The key caps on the keyboard are fragile and easily come off.
  5. Dell Inspiron 5100 PP07L CD Drive Replacement, Screen: step 5, image 1 of 2 Dell Inspiron 5100 PP07L CD Drive Replacement, Screen: step 5, image 2 of 2
    • Using a Phillips screwdriver remove the two screws (5.8mm) located at the rear of the laptop.
  6. Dell Inspiron 5100 PP07L CD Drive Replacement: step 6, image 1 of 1
    • Detach the screen connector.
  7. Dell Inspiron 5100 PP07L CD Drive Replacement: step 7, image 1 of 2 Dell Inspiron 5100 PP07L CD Drive Replacement: step 7, image 2 of 2
    • Using a Phillips screwdriver remove the four screws (5.8 mm) located at hinges of the screen.
  8. Dell Inspiron 5100 PP07L CD Drive Replacement: step 8, image 1 of 1
    • Lift and remove display screen.
  9. Dell Inspiron 5100 PP07L CD Drive Replacement, CD Drive: step 9, image 1 of 2 Dell Inspiron 5100 PP07L CD Drive Replacement, CD Drive: step 9, image 2 of 2
    • Flip to the back side of the laptop.
    • Remove thirteen screws (8.6mm).
    • If battery has not yet been removed, remove it now and remove single silver-colored screw at top of empty battery bay.
  10. Dell Inspiron 5100 PP07L CD Drive Replacement: step 10, image 1 of 2 Dell Inspiron 5100 PP07L CD Drive Replacement: step 10, image 2 of 2
    • Remove one screw (8.6 mm) on metal plating.
    • Remove the metal plating.
  11. Dell Inspiron 5100 PP07L CD Drive Replacement: step 11, image 1 of 1
    • Remove two screws (5.8mm)
  12. Dell Inspiron 5100 PP07L CD Drive Replacement: step 12, image 1 of 2 Dell Inspiron 5100 PP07L CD Drive Replacement: step 12, image 2 of 2
    • Disconnect cable.
  13. Dell Inspiron 5100 PP07L CD Drive Replacement: step 13, image 1 of 2 Dell Inspiron 5100 PP07L CD Drive Replacement: step 13, image 2 of 2
    • Make sure that single silver-colored screw has been removed from empty battery bay
    • Remove top cover by lifting the edges upward.
  14. Dell Inspiron 5100 PP07L CD Drive Replacement: step 14, image 1 of 2 Dell Inspiron 5100 PP07L CD Drive Replacement: step 14, image 2 of 2
    • Remove CD drive plating screw (5.8mm)
  15. Dell Inspiron 5100 PP07L CD Drive Replacement: step 15, image 1 of 1
    • Slide outwards to remove
May Chauvin
201 Reputation
6 Guides authored
Cal Poly, Team 12-34, Maness Spring 2011 Member of Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 12
All Time: 4,485
