Dell Inspiron E1705 Motherboard Replacement
  1. Dell Inspiron E1705 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Dell Inspiron E1705 Motherboard Replacement: step 2, image 1 of 2 Dell Inspiron E1705 Motherboard Replacement: step 2, image 2 of 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Dell Inspiron E1705 Motherboard Replacement, Hard Drive: step 3, image 1 of 2 Dell Inspiron E1705 Motherboard Replacement, Hard Drive: step 3, image 2 of 2
    • Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment.
    • These screws hold the hard drive tray into the hard drive compartment.
  4. Dell Inspiron E1705 Motherboard Replacement: step 4, image 1 of 1
    • Slide the hard drive tray out of the hard drive compartment.
  5. Dell Inspiron E1705 Motherboard Replacement, Optical Drive: step 5, image 1 of 1
    • Locate and remove the screw shown
    • It is labeled with a lock symbol
  6. Dell Inspiron E1705 Motherboard Replacement: step 6, image 1 of 2 Dell Inspiron E1705 Motherboard Replacement: step 6, image 2 of 2
    • Use the screwdriver to gently push the optical drive out
  7. Dell Inspiron E1705 Motherboard Replacement, Lower Case: step 7, image 1 of 1
    • Remove the 12 Phillips #1 screws from the edges of the lower case.
    • You may also need to remove the central screw next to the lock icon.
  8. Dell Inspiron E1705 Motherboard Replacement: step 8, image 1 of 3 Dell Inspiron E1705 Motherboard Replacement: step 8, image 2 of 3 Dell Inspiron E1705 Motherboard Replacement: step 8, image 3 of 3
    • Turn the computer back over and tilt the screen open.
    • Use the plastic opening tool to carefully pry the panel out as shown in the pictures
    • Remove the plastic panel carefully.
  9. Dell Inspiron E1705 Motherboard Replacement: step 9, image 1 of 3 Dell Inspiron E1705 Motherboard Replacement: step 9, image 2 of 3 Dell Inspiron E1705 Motherboard Replacement: step 9, image 3 of 3
    • Use the small Phillips head screwdriver to remove the screws circled in red.
    • Gently lift the keyboard up and rest it just below the screen as shown in the picture.
    • The keyboard will still be connected to the motherboard.
  10. Dell Inspiron E1705 Motherboard Replacement: step 10, image 1 of 2 Dell Inspiron E1705 Motherboard Replacement: step 10, image 2 of 2
    • Before removing the keyboard completely, use the plastic opening tool to gently lift the clamp connecting the keyboard to the motherboard.
    • Once the keyboard has been disconnected, remove the keyboard completely.
  11. Dell Inspiron E1705 Motherboard Replacement: step 11, image 1 of 3 Dell Inspiron E1705 Motherboard Replacement: step 11, image 2 of 3 Dell Inspiron E1705 Motherboard Replacement: step 11, image 3 of 3
    • Using a Phillips head screwdriver, remove the screws shown in the image. They all have the letter "P" next to them.
    • Carefully unplug the connections shown.
    • Don't forget the display cable. It is slightly to the right of the Dell logo at the top.
    • Also, the wireless cables on the right side may prevent moving the upper case out of the way.
    • Once the screws have been removed and the connections unplugged, use the plastic opening tool to gently separate the panel from the lower case.
  12. Dell Inspiron E1705 Motherboard Replacement: step 12, image 1 of 1
    • Remove the plastic case by gently bending back towards the screen. You can bend the screen all the way back if that helps.
    • For the motherboard the optical drive will be removed already. However for the lower case it is not necessary that it be taken out.
    • If you are having trouble removing the upper plastic case (and LCD) from the lower case, there may still be a wire connected to the Wi-Fi adapter. Turn the laptop over, open the Wi-Fi module access panel and remove the + and - leads for the Wi-Fi antenna.
  13. Dell Inspiron E1705 Motherboard Replacement, Heat Sink: step 13, image 1 of 1
    • Unscrew the 4 screws shown in the picture.
    • Screws will not come out all the way.
  14. Dell Inspiron E1705 Motherboard Replacement: step 14, image 1 of 2 Dell Inspiron E1705 Motherboard Replacement: step 14, image 2 of 2
    • Remove the heat sync gently
  15. Dell Inspiron E1705 Motherboard Replacement: step 15, image 1 of 3 Dell Inspiron E1705 Motherboard Replacement: step 15, image 2 of 3 Dell Inspiron E1705 Motherboard Replacement: step 15, image 3 of 3
    • The right heat sync is connected to the videocard. To remove the heat sync requires also removing the videocard.
    • Remove the 4 screws indicated in the first picture
    • Screws will not totally come out.
    • Gently lift up the videocard and heat sync from the motherboard.
  16. Dell Inspiron E1705 Motherboard Replacement, Motherboard: step 16, image 1 of 3 Dell Inspiron E1705 Motherboard Replacement, Motherboard: step 16, image 2 of 3 Dell Inspiron E1705 Motherboard Replacement, Motherboard: step 16, image 3 of 3
    • Remove both fans from the computer. This will make it easier to remove the motherboard.
    • Remove the screws in the photos to remove the fans.
  17. Dell Inspiron E1705 Motherboard Replacement: step 17, image 1 of 1
    • Unplug the shown leads by gently pulling them up.
    • Remove the shown screws from the motherboard
  18. Dell Inspiron E1705 Motherboard Replacement: step 18, image 1 of 3 Dell Inspiron E1705 Motherboard Replacement: step 18, image 2 of 3 Dell Inspiron E1705 Motherboard Replacement: step 18, image 3 of 3
    • Gently remove the motherboard from the laptop by simultaneously lifting and pulling away from the sides.
    • Once the motherboard is free, flip it over, towards the screen of the laptop and gently remove the black and white wire from the wireless card.
    • Once the wires are disconnected, pull them through the hole and completely remove the motherboard from the computer.
  19. Dell Inspiron E1705 Motherboard Replacement: step 19, image 1 of 1
    • Your computer should look like the computer in the photo without the motherboard.
5 other people completed this guide.
Malik Shahbal
471 Reputation
5 Guides authored
Cal Poly, Team 22-5, Maness Fall 2010 Member of Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 17,448
