Kid Motorz Xtreme Quad 12V Vehicle Battery Repair
  1. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair, Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: step 1, image 1 of 1
    • Remove the screw at the back of the seat.
    • Remove the seat from the device.
  2. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: step 2, image 1 of 1
    • Remove the two screws along the bracket.
    • Remove the bracket.
  3. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: step 3, image 1 of 1
    • Disconnect battery by gently pushing the tabs inwards and carefully unplugging it.
  4. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: step 4, image 1 of 2 Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: step 4, image 2 of 2
    • Remove the battery terminals and the battery.
  5. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: step 5, image 1 of 1
    • Put safety gloves on before beginning to solder.
    • Take your solder and place it carefully on the terminal points of the battery (negative and positive).
  6. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: step 6, image 1 of 1
    • Apply heat to the solder.
  7. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: step 7, image 1 of 2 Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: step 7, image 2 of 2
    • Position the wire onto the end piece and apply heat to the solder.
  8. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: step 8, image 1 of 2 Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: step 8, image 2 of 2
    • Put the battery back into its compartment.
    • Plug the battery back in.
  9. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: step 9, image 1 of 1
    • Place the bracket back into its slot.
    • Screw the bracket screws back into place.
  10. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: step 10, image 1 of 1
    • Place the seat back onto the device.
    • Screw the seat screw back into place.
  11. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: step 11, image 1 of 1
    • Congratulations you are now ready to ride again!
The goal of this guide is to repair a battery terminal through solder and after completing the guide you should be able to apply what you learned to other projects and similar electronics
Yanal
243 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 152
