Kindle 7th Generation Front Panel Replacement
  1. Kindle 7th Generation Front Panel Replacement, Front Panel: step 1, image 1 of 2 Kindle 7th Generation Front Panel Replacement, Front Panel: step 1, image 2 of 2
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
  2. Kindle 7th Generation Front Panel Replacement: step 2, image 1 of 1
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
4 other people completed this guide.
Abby Roulier
966 Reputation
3 Guides authored
Cal Poly, Team 6-28, Amido Winter 2015 Member of Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 39
All Time: 5,025
