Introduction
Use this guide to replace the back cover on your Kobo Clara Colour eReader.
The back cover includes the external power button.
Note: Replacement back covers don't have a printed serial number, so you'll have to refer to your eReader's internal settings for your serial number after this repair.
Kobo supports their eReaders with a warranty. If your device is still under warranty, Kobo may be able to help. Before starting a repair, review your warranty information or check support documentation.
Lay your eReader down so the back cover is facing up.
Insert the flat edge of an opening pick between the frame and the bottom left corner of the back cover.
Push the pick downwards at a slight angle until it slides under the back cover.
Slide the pick toward the bottom right corner to release the clips along the bottom edge.
Slide the pick toward the top left corner to release the clips along the left edge.
Grip the left edge of the back cover and lift it away from the eReader to release the remaining clips.
Remove the back cover.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
