LG CineBeam Wi-Fi and Bluetooth Card Replacement
  1. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Bottom Plate: step 1, image 1 of 1
    • Remove three 6 mm screws on the bottom plate with a Phillips #00 screwdriver.
  2. LG CineBeam Wi-Fi and Bluetooth Card Replacement: step 2, image 1 of 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: step 2, image 2 of 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: step 2, image 3 of 3
    • Using an iFixit opening tool, pry the bottom plate off of the device and remove it fully.
  3. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Motherboard: step 3, image 1 of 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Motherboard: step 3, image 2 of 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Motherboard: step 3, image 3 of 3
    • Using an iFixit opening tool, press down the lever on the top of the minilock connector for the speaker and pull the plug out gently.
    • Repeat this process to remove the WiFi/Bluetooth card connector.
    • Remove the battery connector.
    • Remove the fan connectors.
  4. LG CineBeam Wi-Fi and Bluetooth Card Replacement: step 4, image 1 of 2 LG CineBeam Wi-Fi and Bluetooth Card Replacement: step 4, image 2 of 2
    • Using an iFixit opening tool, pry up the black plastic tabs on the back of the power button/joystick board cable.
    • Gently pull the ribbon cable out of the socket.
    • Repeat this process for the two display cables.
  5. LG CineBeam Wi-Fi and Bluetooth Card Replacement: step 5, image 1 of 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: step 5, image 2 of 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: step 5, image 3 of 3
    • Lift the motherboard out of the casing.
  6. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Speaker: step 6, image 1 of 2 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Speaker: step 6, image 2 of 2
    • Use your fingers to lift the speaker from the casing.
  7. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Battery: step 7, image 1 of 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Battery: step 7, image 2 of 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Battery: step 7, image 3 of 3
    • Turn the device over so the power button is facing up.
    • Using an iFixit opening tool, pry open the top of the plastic casing and remove it completely.
  8. LG CineBeam Wi-Fi and Bluetooth Card Replacement: step 8, image 1 of 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: step 8, image 2 of 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: step 8, image 3 of 3
    • Using an iFixit opening tool, remove the battery.
  9. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Wi-Fi and Bluetooth Card: step 9, image 1 of 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Wi-Fi and Bluetooth Card: step 9, image 2 of 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Wi-Fi and Bluetooth Card: step 9, image 3 of 3
    • Using an iFixit opening tool, move the plastic clip on the right side of the board out of the way.
    • Using an iFixit opening tool, pry the Wi-Fi and Bluetooth card out of its socket.
John Dalton
393 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 178
