LG Refrigerator LFX25973 Condenser Fan Motor Replacement
  1. LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser Fan Motor
    • Compressor Motor and Thermal Overload Device
    • Water Supply Valve Assembly
  2. LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Unfasten the condenser cover: step 2, image 1 of 1
    • Use a Phillips screwdriver to remove the six 14.5 mm‑long screws securing the condenser cover to the rear of the refrigerator.
  3. LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Remove the condenser cover: step 3, image 1 of 3 LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Remove the condenser cover: step 3, image 2 of 3 LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Remove the condenser cover: step 3, image 3 of 3
    • Tilt the top edge of the condenser cover toward you.
    • Lift and remove the condenser cover.
  4. LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Disconnect the condenser fan: step 4, image 1 of 2 LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Disconnect the condenser fan: step 4, image 2 of 2
    • Squeeze and pull the condenser fan connector straight down to disconnect the condenser fan.
  5. LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Unfasten the condenser fan shroud: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove the 18.3 mm‑long condenser fan shroud screw.
  6. LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Remove the condenser fan blade assembly: step 6, image 1 of 3 LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Remove the condenser fan blade assembly: step 6, image 2 of 3 LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Remove the condenser fan blade assembly: step 6, image 3 of 3
    • Place a pair of slip joint pliers around the condenser fan drive shaft.
    • Place a large flat blade screwdriver between the slip joint pliers and the fan hub.
    • While holding the pliers in place, push the screwdriver against the pliers to pry the fan off.
  7. LG Refrigerator LFX25973 Condenser Fan Motor Replacement: step 7, image 1 of 2 LG Refrigerator LFX25973 Condenser Fan Motor Replacement: step 7, image 2 of 2
    • Remove the fan blade assembly.
  8. LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Remove the condenser fan motor: step 8, image 1 of 3 LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Remove the condenser fan motor: step 8, image 2 of 3 LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Remove the condenser fan motor: step 8, image 3 of 3
    • Use a stubby Phillips screwdriver to remove the two 22.5 mm‑long screws securing the fan motor inside the fan motor bracket.
    • You may find it easier to use a 1/4 inch drive socket with a Phillips head bit to remove the screws.
  9. LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Remove the fan motor: step 9, image 1 of 3 LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Remove the fan motor: step 9, image 2 of 3 LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Remove the fan motor: step 9, image 3 of 3
    • Push apart the two halves of the fan motor bracket to release the fan motor.
    • Slide the fan motor shaft up through the slot in the front fan motor bracket.
  10. LG Refrigerator LFX25973 Condenser Fan Motor Replacement: step 10, image 1 of 2 LG Refrigerator LFX25973 Condenser Fan Motor Replacement: step 10, image 2 of 2
    • Remove the fan motor.
  11. LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Transfer the motor mounting washers: step 11, image 1 of 3 LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Transfer the motor mounting washers: step 11, image 2 of 3 LG Refrigerator LFX25973 Condenser Fan Motor Replacement, Transfer the motor mounting washers: step 11, image 3 of 3
    • Transfer the two rubber motor mounting washers from the old motor to the new motor.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
30,362 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,525 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 11
All Time: 68
