LG Refrigerator LFX25973 Freezer Ice Maker Replacement
  1. LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser Fan Motor
    • Compressor Motor and Thermal Overload Device
    • Water Supply Valve Assembly
  2. LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Open the freezer door: step 2, image 1 of 2 LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Open the freezer door: step 2, image 2 of 2
    • Pull open the freezer door fully.
  3. LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Remove the drawer and bin: step 3, image 1 of 3 LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Remove the drawer and bin: step 3, image 2 of 3 LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Remove the drawer and bin: step 3, image 3 of 3
    • Lift and remove the upper pull-out drawer.
    • Lift and remove the main drawer bin.
  4. LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Remove the drawer rail covers: step 4, image 1 of 3 LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Remove the drawer rail covers: step 4, image 2 of 3 LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Remove the drawer rail covers: step 4, image 3 of 3
    • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
    • Lift the cover off of the rail and remove it.
    • Repeat this procedure for the left drawer rail cover.
  5. LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Reassembly notes: step 5, image 1 of 2 LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Reassembly notes: step 5, image 2 of 2
    • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
    • Hold the drawer rail cover flush against the side of the drawer rail.
    • You should feel the locking tabs protruding.
    • Push the rail cover straight downward to install. It should click into place.
  6. LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Remove the drawer: step 6, image 1 of 2 LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Remove the drawer: step 6, image 2 of 2
    • Use a Phillips screwdriver to remove the 10.4 mm‑long screw securing the drawer to each of the drawer slides.
  7. LG Refrigerator LFX25973 Freezer Ice Maker Replacement: step 7, image 1 of 3 LG Refrigerator LFX25973 Freezer Ice Maker Replacement: step 7, image 2 of 3 LG Refrigerator LFX25973 Freezer Ice Maker Replacement: step 7, image 3 of 3
    • Lift the front of the drawer up.
    • Pull the drawer toward you to release the drawer from the drawer slides.
    • Remove the freezer drawer.
  8. LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Release the ice maker: step 8, image 1 of 1
    • Use a Phillips screwdriver to remove the two 22.5 mm‑long screws securing the ice maker to the top of the freezer compartment.
  9. LG Refrigerator LFX25973 Freezer Ice Maker Replacement: step 9, image 1 of 3 LG Refrigerator LFX25973 Freezer Ice Maker Replacement: step 9, image 2 of 3 LG Refrigerator LFX25973 Freezer Ice Maker Replacement: step 9, image 3 of 3
    • Insert a flat-blade screwdriver into the slot located on the right edge of the ice maker.
    • Pry outward with the screwdriver to release the locking tab securing the ice maker to the fridge.
    • When the tab releases, pull the right front corner of the ice maker down.
  10. LG Refrigerator LFX25973 Freezer Ice Maker Replacement: step 10, image 1 of 1
    • Repeat the previous operation on the left side of the ice maker to release it.
  11. LG Refrigerator LFX25973 Freezer Ice Maker Replacement: step 11, image 1 of 3 LG Refrigerator LFX25973 Freezer Ice Maker Replacement: step 11, image 2 of 3 LG Refrigerator LFX25973 Freezer Ice Maker Replacement: step 11, image 3 of 3
    • Grasp the front edge of the ice maker and pull it towards you.
    • Lower the ice maker.
  12. LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Disconnect and remove the ice maker: step 12, image 1 of 3 LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Disconnect and remove the ice maker: step 12, image 2 of 3 LG Refrigerator LFX25973 Freezer Ice Maker Replacement, Disconnect and remove the ice maker: step 12, image 3 of 3
    • Squeeze the ice maker connector to release it and pull it straight out to disconnect it.
    • Remove the ice maker.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
30,362 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,525 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 44
