LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement
  1. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser Fan Motor
    • Compressor Motor and Thermal Overload Device
    • Water Supply Valve Assembly
  2. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Open the freezer door: step 2, image 1 of 2 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Open the freezer door: step 2, image 2 of 2
    • Pull open the freezer door fully.
  3. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the drawer and bin: step 3, image 1 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the drawer and bin: step 3, image 2 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the drawer and bin: step 3, image 3 of 3
    • Lift and remove the upper pull-out drawer.
    • Lift and remove the main drawer bin.
  4. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the drawer rail covers: step 4, image 1 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the drawer rail covers: step 4, image 2 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the drawer rail covers: step 4, image 3 of 3
    • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
    • Lift the cover off of the rail and remove it.
    • Repeat this procedure for the left drawer rail cover.
  5. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Reassembly notes: step 5, image 1 of 2 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Reassembly notes: step 5, image 2 of 2
    • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
    • Hold the drawer rail cover flush against the side of the drawer rail.
    • You should feel the locking tabs protruding.
    • Push the rail cover straight downward to install. It should click into place.
  6. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the drawer: step 6, image 1 of 2 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the drawer: step 6, image 2 of 2
    • Use a Phillips screwdriver to remove the 10.4 mm‑long screw securing the drawer to each of the drawer slides.
  7. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 7, image 1 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 7, image 2 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 7, image 3 of 3
    • Lift the front of the drawer up.
    • Pull the drawer toward you to release the drawer from the drawer slides.
    • Remove the freezer drawer.
  8. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Release the drawer slides: step 8, image 1 of 1
    • Use a Phillips screwdriver to remove the five 22.4 mm‑long screws securing both left drawer slides.
  9. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the upper left drawer slide: step 9, image 1 of 2 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the upper left drawer slide: step 9, image 2 of 2
    • Pull the upper left drawer slide slightly towards you to release the locking tab at the rear.
    • Remove the upper left drawer slide.
  10. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Release lower left drawer slide and reposition it: step 10, image 1 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Release lower left drawer slide and reposition it: step 10, image 2 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Release lower left drawer slide and reposition it: step 10, image 3 of 3
    • Pull the lower left drawer slide slightly toward you to release the locking tab at the rear.
    • Reposition the lower left drawer slide to gain access to the door switch connector.
  11. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Disconnect the drawer switch and remove the lower slide: step 11, image 1 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Disconnect the drawer switch and remove the lower slide: step 11, image 2 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Disconnect the drawer switch and remove the lower slide: step 11, image 3 of 3
    • Squeeze the door switch connector to release it.
    • Pull the door switch connector down to disconnect it.
    • Remove the lower left drawer slide.
    • If you are removing the freezer evaporator cover, only the left-hand slides need to be removed.
  12. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Release the ice maker: step 12, image 1 of 1
    • Use a Phillips screwdriver to remove the two 22.5 mm‑long screws securing the ice maker to the top of the freezer compartment.
  13. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 13, image 1 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 13, image 2 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 13, image 3 of 3
    • Insert a flat-blade screwdriver into the slot located on the right edge of the ice maker.
    • Pry outward with the screwdriver to release the locking tab securing the ice maker to the fridge.
    • When the tab releases, pull the right front corner of the ice maker down.
  14. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 14, image 1 of 1
    • Repeat the previous operation on the left side of the ice maker to release it.
  15. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 15, image 1 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 15, image 2 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 15, image 3 of 3
    • Grasp the front edge of the ice maker and pull it towards you.
    • Lower the ice maker.
  16. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Disconnect and remove the ice maker: step 16, image 1 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Disconnect and remove the ice maker: step 16, image 2 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Disconnect and remove the ice maker: step 16, image 3 of 3
    • Squeeze the ice maker connector to release it and pull it straight out to disconnect it.
    • Remove the ice maker.
  17. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove air return cover: step 17, image 1 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove air return cover: step 17, image 2 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove air return cover: step 17, image 3 of 3
    • Pinch the rear portion of the air return cover to release it from the freezer wall.
    • Pull the air return cover outward and remove it.
  18. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Unfasten the evaporator cover: step 18, image 1 of 1
    • Use a Phillips screwdriver to remove the 18.8 mm‑long screw securing the evaporator cover.
  19. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Reposition the evaporator cover: step 19, image 1 of 2 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Reposition the evaporator cover: step 19, image 2 of 2
    • Don't try to remove the evaporator cover fully, as It is still connected to the fridge with a number of wires.
    • Grasp the evaporator cover by the air vent openings and pull the top edge toward you.
  20. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 20, image 1 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 20, image 2 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 20, image 3 of 3
    • Lift the evaporator cover slightly to release the tabs at the lower edge.
    • Swing the left edge of the evaporator cover toward you and lower it.
  21. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Disconnect the evaporator cover: step 21, image 1 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Disconnect the evaporator cover: step 21, image 2 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Disconnect the evaporator cover: step 21, image 3 of 3
    • Disconnect the two electrical connections in the upper left corner of the freezer.
  22. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 22, image 1 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 22, image 2 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement: step 22, image 3 of 3
    • Swing the left edge of the evaporator cover further toward you to access the connections in the upper right corner.
    • Squeeze and pull the connector with the blue wires to disconnect the thermistor mounted in the evaporator cover.
  23. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the evaporator cover: step 23, image 1 of 2 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the evaporator cover: step 23, image 2 of 2
    • Remove the evaporator cover.
  24. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Peel up the insulation: step 24, image 1 of 2 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Peel up the insulation: step 24, image 2 of 2
    • On the rear of the evaporator cover, peel up the insulation pad covering the thermistor.
  25. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the thermistor: step 25, image 1 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the thermistor: step 25, image 2 of 3 LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Remove the thermistor: step 25, image 3 of 3
    • Use a spudger to pry the thermistor out of its mounting clips.
    • Thread the thermistor through the slot in the insulation pad and remove it.
  26. LG Refrigerator LFX25973 Freezer Thermistor Test and Replacement, Test the thermistor: step 26, image 1 of 1
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Attached Documents
Bill Gilbert
30,362 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,525 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 64
