LG VX5200 Camera Replacement
  1. LG VX5200 Camera Replacement, Battery: step 1, image 1 of 2 LG VX5200 Camera Replacement, Battery: step 1, image 2 of 2
    • Turn the phone on its back.
  2. LG VX5200 Camera Replacement: step 2, image 1 of 2 LG VX5200 Camera Replacement: step 2, image 2 of 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 Camera Replacement: step 3, image 1 of 2 LG VX5200 Camera Replacement: step 3, image 2 of 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 Camera Replacement, Face Plate: step 4, image 1 of 3 LG VX5200 Camera Replacement, Face Plate: step 4, image 2 of 3 LG VX5200 Camera Replacement, Face Plate: step 4, image 3 of 3
    • Flip the phone open.
    • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
    • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
  5. LG VX5200 Camera Replacement: step 5, image 1 of 3 LG VX5200 Camera Replacement: step 5, image 2 of 3 LG VX5200 Camera Replacement: step 5, image 3 of 3
    • Insert the opening tool in the seam of the top portion of the flip phone.
    • Gently pry the seam open.
    • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
  6. LG VX5200 Camera Replacement: step 6, image 1 of 3 LG VX5200 Camera Replacement: step 6, image 2 of 3 LG VX5200 Camera Replacement: step 6, image 3 of 3
    • Close the flip phone.
    • Hold the base of the phone and gently remove the faceplate.
    • Place the phone and the faceplate on a clean, flat surface.
  7. LG VX5200 Camera Replacement, Camera: step 7, image 1 of 3 LG VX5200 Camera Replacement, Camera: step 7, image 2 of 3 LG VX5200 Camera Replacement, Camera: step 7, image 3 of 3
    • Locate the phone camera.
    • Locate the white rubber stopper to left of the camera.
    • Remove white rubber stopper by grabbing an edge with your fingers and gently pulling it off.
  8. LG VX5200 Camera Replacement: step 8, image 1 of 2 LG VX5200 Camera Replacement: step 8, image 2 of 2
    • Lift the copper ribbon cable up from the bottom right hand corner.
  9. LG VX5200 Camera Replacement: step 9, image 1 of 2 LG VX5200 Camera Replacement: step 9, image 2 of 2
    • While holding the copper connection out of the way, use your fingernail to pry the camera out of its socket.
2 other people completed this guide.
Douglas Blaalid
282 Reputation
8 Guides authored
Cal Poly, Team 4-13, Forte Winter 2010 Member of Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 2,203
