Lenovo 100e Chromebook (1st Gen) Wi-Fi/Bluetooth Card Replacement
  1. Lenovo 100e Chromebook (1st Gen) Wi-Fi/Bluetooth Card Replacement, Get the equipment ready: step 1, image 1 of 2 Lenovo 100e Chromebook (1st Gen) Wi-Fi/Bluetooth Card Replacement, Get the equipment ready: step 1, image 2 of 2
    • Unplug and turn off the chromebook device.
  2. Lenovo 100e Chromebook (1st Gen) Wi-Fi/Bluetooth Card Replacement, Remove back cover: step 2, image 1 of 3 Lenovo 100e Chromebook (1st Gen) Wi-Fi/Bluetooth Card Replacement, Remove back cover: step 2, image 2 of 3 Lenovo 100e Chromebook (1st Gen) Wi-Fi/Bluetooth Card Replacement, Remove back cover: step 2, image 3 of 3
    • Turn the laptop over.
    • Remove the 10 phillips head screws and keep them organized.
    • Using a Spudger, carefully separate the cover from the corner. It snaps back in, so make sure to not break any clips.
    • Take out the cover and set it aside.
  3. Lenovo 100e Chromebook (1st Gen) Wi-Fi/Bluetooth Card Replacement, Disconnect the battery: step 3, image 1 of 2 Lenovo 100e Chromebook (1st Gen) Wi-Fi/Bluetooth Card Replacement, Disconnect the battery: step 3, image 2 of 2
    • In the lower side of the motherboard you will find the battery connector.
    • To disconnect the battery, carefully pull the black connector in a parallel direction to the laptop.
    • Remember to take the conector out fully to avoid any shortcircuits.
  4. Lenovo 100e Chromebook (1st Gen) Wi-Fi/Bluetooth Card Replacement, Remove Wi-Fi Card: step 4, image 1 of 3 Lenovo 100e Chromebook (1st Gen) Wi-Fi/Bluetooth Card Replacement, Remove Wi-Fi Card: step 4, image 2 of 3 Lenovo 100e Chromebook (1st Gen) Wi-Fi/Bluetooth Card Replacement, Remove Wi-Fi Card: step 4, image 3 of 3
    • You will find the Card on the top left corner of the chassis.
    • Carefully disconnect the antenna cables from the card with an upward movement.
    • Notice these cables have colors that match the ones printed on the sticker of the Card.
    • Remove the Phillips head screw.
    • Pull from the motherboard in a parallel direction.
  5. Lenovo 100e Chromebook (1st Gen) Wi-Fi/Bluetooth Card Replacement, Wi-Fi Card Overview: step 5, image 1 of 2 Lenovo 100e Chromebook (1st Gen) Wi-Fi/Bluetooth Card Replacement, Wi-Fi Card Overview: step 5, image 2 of 2
    • This is an Intel WiFi + Bluetooth Combo card. The model on this card is "7265NGW".
    • It has a M.2 1216 size format.
    • Wi-Fi 5 (802.11ac) and Dual Band (2.4 GHz and 5.0 GHz) compatible.
    • Bluetooth 4.2 compliant.
To reassemble your device, follow these instructions in reverse order. Congrats! You've upgraded your Wi-Fi Card.
Franco Iván Bello Rojas
869 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 22
All Time: 123
