Lenovo G50-80 80E5 Power Supply Jack Replacement
  1. Lenovo G50-80 80E5 Power Supply Jack Replacement, Battery: step 1, image 1 of 1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 2, image 1 of 3 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 2, image 2 of 3 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 2, image 3 of 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 3, image 1 of 3 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 3, image 2 of 3 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 3, image 3 of 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 4, image 1 of 3 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 4, image 2 of 3 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 4, image 3 of 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Power Supply Jack Replacement, Bottom Access Panel: step 5, image 1 of 2 Lenovo G50-80 80E5 Power Supply Jack Replacement, Bottom Access Panel: step 5, image 2 of 2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 6, image 1 of 2 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 6, image 2 of 2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Power Supply Jack Replacement, CD Drive: step 7, image 1 of 2 Lenovo G50-80 80E5 Power Supply Jack Replacement, CD Drive: step 7, image 2 of 2
    • Locate the CD drive.
    • Remove the single #00 Phillips 5.5 mm screw on the centermost side of the drive.
  8. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 8, image 1 of 2 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 8, image 2 of 2
    • Move the drive towards the outside of the laptop to remove the connector.
    • Pull the drive out of the laptop.
  9. Lenovo G50-80 80E5 Power Supply Jack Replacement, Keyboard: step 9, image 1 of 3 Lenovo G50-80 80E5 Power Supply Jack Replacement, Keyboard: step 9, image 2 of 3 Lenovo G50-80 80E5 Power Supply Jack Replacement, Keyboard: step 9, image 3 of 3
    • Locate the 3 screws on the bottom, securing the keyboard.
    • One Screw will be located under Lenovo sticker. Break sticker to gain access to screw.
  10. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 10, image 1 of 1
    • Starting on side, gently pry up using spudge.
  11. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 11, image 1 of 2 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 11, image 2 of 2
    • Continue prying around top of keyboard
  12. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 12, image 1 of 1
    • Once the top of keyboard is loose, gently lift up
  13. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 13, image 1 of 1
    • lift up bottom of keyboard slightly, to access keyboard ribbon
  14. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 14, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, lift up clip to remove keyboard ribbon cable.
  15. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 15, image 1 of 2 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 15, image 2 of 2
    • Keyboard ribbon cable removed
    • Once ribbon is removed, keyboard can be lifted out
  16. Lenovo G50-80 80E5 Power Supply Jack Replacement, Removing top panel: step 16, image 1 of 1
    • Remove wifi wires by lifting up
  17. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 17, image 1 of 1
    • locate power and monitor cable on bottom side next to fan
  18. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 18, image 1 of 1
    Buy
    • remove power cable with tweezers by gently pullying
  19. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 19, image 1 of 1
    • remove monitor cable by gently pulling on tab straight up
  20. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 20, image 1 of 1
    • Monitor and power cable disconnected
  21. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 21, image 1 of 1
    • Disconnect the fan wires from the motherboard by lifting upwards
  22. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 22, image 1 of 3 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 22, image 2 of 3 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 22, image 3 of 3
    • Locate the 3 screws holding fan in place
    • Remove 3 screws
    • fan should lift out of place
  23. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 23, image 1 of 1
    • lift clip to remove ribbon cable for think pad.
  24. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 24, image 1 of 2 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 24, image 2 of 2
    • lift clip to remove power button ribbon cable.
  25. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 25, image 1 of 1
    • Begin by locating screws on bottom panel
  26. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 26, image 1 of 1
    • Remove screws using a 001 phillips screw driver.
  27. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 27, image 1 of 3 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 27, image 2 of 3 Lenovo G50-80 80E5 Power Supply Jack Replacement: step 27, image 3 of 3
    • Once screws are removed, begin by gently prying up in one corner using a spudge
    • Continue to center and then around to opposite side.
    • once all sides have been pried open, lift top half off
  28. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 28, image 1 of 1
    • Top covered removed
  29. Lenovo G50-80 80E5 Power Supply Jack Replacement, Power Supply Jack: step 29, image 1 of 2 Lenovo G50-80 80E5 Power Supply Jack Replacement, Power Supply Jack: step 29, image 2 of 2
    • lift up power jack and remove from holding tabs
  30. Lenovo G50-80 80E5 Power Supply Jack Replacement: step 30, image 1 of 1
    • power jack removed
11 other people completed this guide.
Victor
1,282 Reputation
4 Guides authored
4 Comments
TY TY fixed myself for 7$
manx_44709 - Reply
Should the new Power Jack look exactly the same as the manufacturer one? My original Power Jack has prongs but the new one does not and the laptop will not power on.
gifts.fromgod - Reply
Does this require soldering as well ?
Explorer Gurus - Reply
I would not rate this as a difficult task and I managed to complete the dismantle and reassemble within the 45 Minutes, Overall a pretty good description. The hardest bit was reattaching the wifi wires. I found I did not need tweezers and used a small electrical flat head instead of a spudge. No soldering or other tools. Having bought a new battery and charger (circa $50) the replacement part ($5) and this guide solved the issue. @gifts.fromgod my part was not identical (colour and size of the mid wire join) but fitted more or less and works a charm.
Stephen Connell - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 28
All Time: 9,101
