Lenovo G70-80 RAM Replacement
  1. Lenovo G70-80 RAM Replacement, Battery: step 1, image 1 of 1
    • Turn off the computer.
    • Set the computer upside down with the back facing up.
  2. Lenovo G70-80 RAM Replacement: step 2, image 1 of 2 Lenovo G70-80 RAM Replacement: step 2, image 2 of 2
    • Located directly below the bottom plate will be two switches near where the battery is located.
    • With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
    • To ensure the switch on the right is unlocked, look for a red indicator next to the switch.
  3. Lenovo G70-80 RAM Replacement: step 3, image 1 of 2 Lenovo G70-80 RAM Replacement: step 3, image 2 of 2
    • Slide the left battery release switch to the left.
    • While holding the switch to the left, lift the battery to remove it from the computer.
  4. Lenovo G70-80 RAM Replacement: step 4, image 1 of 2 Lenovo G70-80 RAM Replacement: step 4, image 2 of 2
    • Remove the battery.
  5. Lenovo G70-80 RAM Replacement, RAM: step 5, image 1 of 3 Lenovo G70-80 RAM Replacement, RAM: step 5, image 2 of 3 Lenovo G70-80 RAM Replacement, RAM: step 5, image 3 of 3
    • Remove the placeholder screws and pull off the backplate.
  6. Lenovo G70-80 RAM Replacement: step 6, image 1 of 3 Lenovo G70-80 RAM Replacement: step 6, image 2 of 3 Lenovo G70-80 RAM Replacement: step 6, image 3 of 3
    • Carefully pull the two metal retaining clips away from the sides of the RAM module.
    • As the clips release, the RAM module should pop up at an angle.
    • Remove the RAM from the device.
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 25
All Time: 956
