Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition
  1. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Unfasten the back cover: step 1, image 1 of 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Unfasten the back cover: step 1, image 2 of 2
    • Use a T5 Torx driver to remove nine screws securing the back cover.
    • The three screws on the hinge side will be longer.
  2. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 2 Loosen the back cover: step 2, image 1 of 3 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 2 Loosen the back cover: step 2, image 2 of 3 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 2 Loosen the back cover: step 2, image 3 of 3
    • The back cover is held on by plastic tabs around the entire perimeter of the cover.
    • Use plastic pry tools at the seam. I like to start near the hinge.
  3. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 3 Remove the back cover: step 3, image 1 of 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 3 Remove the back cover: step 3, image 2 of 2
    • Once all the tabs are loose, you will be able to remove the cover.
  4. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Disconnect the battery: step 4, image 1 of 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Disconnect the battery: step 4, image 2 of 2
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  5. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Unfasten the battery: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove the four screws securing the battery.
    • Note: Two of the screws on the left in the image will also hold in the SATA drive bracket.
  6. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 6 Remove the battery: step 6, image 1 of 1
    • Remove the battery.
  7. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Unfasten the SATA drive bracket: step 7, image 1 of 1
    • Use a Phillips screwdriver to remove the remaining two screws securing the SATA drive bracket.
  8. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Locate the SATA drive connector: step 8, image 1 of 1
    • The SATA drive connector is below the Wifi adapter and to the right of the M.2 NVME slot.
    • It is the second left connector.
  9. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Prepare SATA drive connector: step 9, image 1 of 3 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Prepare SATA drive connector: step 9, image 2 of 3 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Prepare SATA drive connector: step 9, image 3 of 3
    • Lift the flat cable connector.
  10. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Fold the SATA ribbon cable: step 10, image 1 of 1
    • Fold the cable.
  11. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Insert the SATA drive ribbon cable connector: step 11, image 1 of 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Insert the SATA drive ribbon cable connector: step 11, image 2 of 2
    • Slide the cable in with the blue/non-contact side facing up.
  12. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Close the SATA drive connector: step 12, image 1 of 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Close the SATA drive connector: step 12, image 2 of 2
    • Lower the flat cable connector.
  13. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Note the orientation of the SATA data and power connectors: step 13, image 1 of 1
    • In the example, the power is on top, and data is on the bottom. You'll need to install your SATA drive in the correct orientation.
  14. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the SATA drive in the bracket: step 14, image 1 of 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the SATA drive in the bracket: step 14, image 2 of 2
    • Note the orientation.
  15. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Fasten the SATA drive to the bracket: step 15, image 1 of 1
    • There are 4 screw mount points.
  16. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Connect the drive: step 16, image 1 of 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Connect the drive: step 16, image 2 of 2
    • Connect the SATA drive to the connector.
  17. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the drive in the chassis: step 17, image 1 of 1
    • Place the SATA drive in.
  18. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the battery in the chassis: step 18, image 1 of 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the battery in the chassis: step 18, image 2 of 2
    • Place the battery in.
  19. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Refasten the bracket and the battery: step 19, image 1 of 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Refasten the bracket and the battery: step 19, image 2 of 2
    • Use a Phillips screwdriver to fasten the six screws securing the SATA drive bracket and battery.
  20. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Reconnect the battery: step 20, image 1 of 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Reconnect the battery: step 20, image 2 of 2
    • Push the battery connector back into place.
E N
422 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 27
All Time: 235
