Lenovo IdeaPad Flex 5-1470 RAM Replacement
  1. Lenovo IdeaPad Flex 5-1470 RAM Replacement, Back Panel: step 1, image 1 of 1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 RAM Replacement: step 2, image 1 of 2 Lenovo IdeaPad Flex 5-1470 RAM Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 RAM Replacement, RAM: step 3, image 1 of 1
    • Use a spudger to gently bend down the locking tabs on the RAM casing.
  4. Lenovo IdeaPad Flex 5-1470 RAM Replacement: step 4, image 1 of 1
    • Use a spudger to gently lift the RAM casing, then lift it up and off.
  5. Lenovo IdeaPad Flex 5-1470 RAM Replacement: step 5, image 1 of 2 Lenovo IdeaPad Flex 5-1470 RAM Replacement: step 5, image 2 of 2
    • Gently take hold of the RAM card and lift slightly.
    • Pull the RAM card directly out of its port.
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 48
All Time: 604
