Lenovo IdeaPad Flex 5-1470 Speaker Replacement
  1. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Back Panel: step 1, image 1 of 1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: step 2, image 1 of 2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Battery: step 3, image 1 of 1
    • Remove the two 3.6 mm Phillips #00 battery screws located in the lower left corner of the device.
  4. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: step 4, image 1 of 2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: step 4, image 2 of 2
    • Gently unplug the multi-colored cable connecting the battery to the motherboard.
    • Remove the battery from the laptop.
  5. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Speaker: step 5, image 1 of 1
    • Remove the two speakers from their compartment. The speakers are held in the bottom corners of the device.
  6. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: step 6, image 1 of 2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully unplug two wired connections from the motherboard using nylon tip reverse tweezers.
Ryan Beste
141 Reputation
1 Guide authored
Cal Poly, Team S2-G5, White Winter 2020 Member of Cal Poly, Team S2-G5, White Winter 2020
CPSU-WHITE-W20S2G5
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 1,147
