Lenovo IdeaPad S340-15IWL RAM Replacement
  1. Lenovo IdeaPad S340-15IWL RAM Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad S340-15IWL RAM Replacement, Back Panel: step 1, image 2 of 2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL RAM Replacement: step 2, image 1 of 1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL RAM Replacement, RAM: step 3, image 1 of 2 Lenovo IdeaPad S340-15IWL RAM Replacement, RAM: step 3, image 2 of 2
    • Using the opening tool, gently pop off the metal cover for the RAM stick.
  4. Lenovo IdeaPad S340-15IWL RAM Replacement: step 4, image 1 of 2 Lenovo IdeaPad S340-15IWL RAM Replacement: step 4, image 2 of 2
    • Using your thumbs, gently pull the two metal prongs that secure the RAM outwards.
    • The RAM will pop up at an angle.
    • Remove the RAM from the laptop.
Kristen Gismondi
83,188 Reputation
204 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,525 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 62
All Time: 1,210
