Lenovo Ideapad 320-15IAP Hard Drive Replacement
  1. Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back panel.
  2. Lenovo Ideapad 320-15IAP Hard Drive Replacement: step 2, image 1 of 2 Lenovo Ideapad 320-15IAP Hard Drive Replacement: step 2, image 2 of 2
    • Remove the CD reader with an opening tool. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Lift the cover using the opening tool on different spots along the side of the laptop.
  3. Lenovo Ideapad 320-15IAP Hard Drive Replacement: step 3, image 1 of 1
    • Remove the hard drive by inserting your finger under the highlighted area, then pushing up then pulling left to remove the drive.
    • Remove the adapter from the drive, then insert the new drive into the adapter.
    • To insert the new drive, gently place it into the enclosure for the hard drive and push carefully into the SATA slot.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 43
All Time: 1,259
