Lenovo Legion 5-15ACH6 SSD Replacement
  1. Lenovo Legion 5-15ACH6 SSD Replacement, SSD: step 1, image 1 of 1
    • Prepare your work area on a flat surface.
    • Lay your laptop down with the back case facing up.
  2. Lenovo Legion 5-15ACH6 SSD Replacement: step 2, image 1 of 1
    • Use a Philips #1 screwdriver to remove the six 11.1 mm on the back of the device.
    • Use a Philips #00 screwdriver to remove the four 4.1 mm screws on the back case.
  3. Lenovo Legion 5-15ACH6 SSD Replacement: step 3, image 1 of 3 Lenovo Legion 5-15ACH6 SSD Replacement: step 3, image 2 of 3 Lenovo Legion 5-15ACH6 SSD Replacement: step 3, image 3 of 3
    • Starting from the back of the laptop slide your opening tool between the bottom cover and laptop chassis.
    • Run the opening tool along the seam to separate the bottom cover from the chassis.
    • Remove the bottom cover and place to the side.
  4. Lenovo Legion 5-15ACH6 SSD Replacement: step 4, image 1 of 3 Lenovo Legion 5-15ACH6 SSD Replacement: step 4, image 2 of 3 Lenovo Legion 5-15ACH6 SSD Replacement: step 4, image 3 of 3
    • To disconnect the battery cable safely, use the pointed tip of a spudger to carefully push on each side of the connector.
    • Alternating from one side to the other, gently “walk” the connector out of its socket.
    • Always pull cables by their connectors and not the wires themselves.
    • Touching any electrical component with the battery plugged in can result in damage to the motherboard.
  5. Lenovo Legion 5-15ACH6 SSD Replacement: step 5, image 1 of 2 Lenovo Legion 5-15ACH6 SSD Replacement: step 5, image 2 of 2
    • Remove the three 4.1mm Phillips #00 screws holding the metal shield in place.
    • Remove the metal shield and place it to the side.
  6. Lenovo Legion 5-15ACH6 SSD Replacement: step 6, image 1 of 1
    • Remove the single 4.1 mm Philips #00 screw holding the SSD in place.
    • Pull the SSD out and away from the socket.
3 other people completed this guide.
Patrick Underwood
175 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 93
All Time: 462
