Lenovo ThinkPad E570 Wi-Fi Card Replacement
  1. Lenovo ThinkPad E570 Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 1 of 1
    • Turn the laptop over so that the bottom is facing upwards.
  2. Lenovo ThinkPad E570 Wi-Fi Card Replacement: step 2, image 1 of 1
    • Unscrew two captive 5 mm screws from the back panel of the laptop using a Phillips #00 screwdriver.
    • Carefully remove the back panel.
  3. Lenovo ThinkPad E570 Wi-Fi Card Replacement: step 3, image 1 of 1
    • Carefully remove the black and white coaxial cables that are connected to the chip using an opening tool.
  4. Lenovo ThinkPad E570 Wi-Fi Card Replacement: step 4, image 1 of 1
    • Remove the single 4 mm screw from the Wi-Fi card using a Phillips #0 screwdriver.
  5. Lenovo ThinkPad E570 Wi-Fi Card Replacement: step 5, image 1 of 1
    • When the screw is removed, the chip will pop up at an angle.
    • Carefully grab the chip and pull outward to remove it from the laptop.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 373
