Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning
Video Overview
  1. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, HDD Cover: step 1, image 1 of 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, HDD Cover: step 1, image 2 of 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, HDD Cover: step 1, image 3 of 3
    • Switch-off the Laptop and remove the battery.
    • The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
    • Remove the Cover.
  2. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, Fan / Cooling System: step 2, image 1 of 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, Fan / Cooling System: step 2, image 2 of 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, Fan / Cooling System: step 2, image 3 of 3
    • Disconnect the Fan cable.
    • Remove the 2x screws from the Fan module.
    • Unscrew 4x screws around the processor.
    • Carefully lift the Cooling System.
  3. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: step 3, image 1 of 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: step 3, image 2 of 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: step 3, image 3 of 3
    • Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound.
    • If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
    • Separate the Fan from the Heat-sink.
  4. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: step 4, image 1 of 1
    • Use a soft anti static brush and clean the Heat-sink on the inside.
    • Before installing a new Cooling System or reinstalling the old one, you must clean the processor from the old thermal compound and put a new one.
3 other people completed this guide.
ZFix
191,647 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,501 Guides authored
3 Comments
Very, very well done video on this guide for the Lenovo Thinkpad e530 laptop.
My compliments to the author of this guide.
James Harnsberger - Reply
will i need thermal paste to do this?
dErpyto3z Eeee - Reply
thanks its clear
Kayan Dev - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 22
All Time: 8,045
