Lenovo ThinkPad T430s RAM Stick Replacement
  1. Lenovo ThinkPad T430s RAM Stick Replacement, Battery: step 1, image 1 of 3 Lenovo ThinkPad T430s RAM Stick Replacement, Battery: step 1, image 2 of 3 Lenovo ThinkPad T430s RAM Stick Replacement, Battery: step 1, image 3 of 3
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: step 2, image 1 of 3 Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: step 2, image 2 of 3 Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: step 2, image 3 of 3
    • With the Phillips #0 screwdriver, loosen the two 30 mm screws holding down the RAM stick plate.
    • Pry up the plate and set it aside.
  3. Lenovo ThinkPad T430s RAM Stick Replacement: step 3, image 1 of 3 Lenovo ThinkPad T430s RAM Stick Replacement: step 3, image 2 of 3 Lenovo ThinkPad T430s RAM Stick Replacement: step 3, image 3 of 3
    • Use the pointy end of the spudger to bend the bars holding the RAM stick in place.
    • Lift the RAM stick up and out of the stick holder.
0 Comments
Past 24 Hours: 2
Past 7 Days: 41
Past 30 Days: 66
All Time: 815
