Lenovo ThinkPad T480 Keyboard Replacement
  1. Lenovo ThinkPad T480 Keyboard Replacement, External Battery: step 1, image 1 of 2 Lenovo ThinkPad T480 Keyboard Replacement, External Battery: step 1, image 2 of 2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Keyboard Replacement: step 2, image 1 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 2, image 2 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 2, image 3 of 3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Keyboard Replacement, Keyboard: step 3, image 1 of 1
    • Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
  4. Lenovo ThinkPad T480 Keyboard Replacement: step 4, image 1 of 1
    • Open the laptop so the keyboard is facing you.
  5. Lenovo ThinkPad T480 Keyboard Replacement: step 5, image 1 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 5, image 2 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 5, image 3 of 3
    • Push the keyboard towards the screen and away from the trackpad and then slide it out towards you gently.
    • The keyboard is connected to the board by two ribbon connectors.
    • Be careful not to rip the connectors when you flip the keyboard over.
  6. Lenovo ThinkPad T480 Keyboard Replacement: step 6, image 1 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 6, image 2 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 6, image 3 of 3
    • Flip the keyboard over towards you to expose the backside of the keyboard and the two ribbon connectors.
    • Using the black nylon spudger, flip the first ribbon connector lock open. Slide the first connector out.
  7. Lenovo ThinkPad T480 Keyboard Replacement: step 7, image 1 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 7, image 2 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 7, image 3 of 3
    • Using the black nylon spudger, unlock the second ribbon connector and slide it out from the port.
  8. Lenovo ThinkPad T480 Keyboard Replacement: step 8, image 1 of 2 Lenovo ThinkPad T480 Keyboard Replacement: step 8, image 2 of 2
    • Remove the keyboard from the laptop.
5 other people completed this guide.
Sarah Westberg
23,468 Reputation
70 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,525 Guides authored
3 Comments
Thanks for this. I need help with my Lenovo Thinkpad T480 keyboard to motherboard connector pin. That is the third image in step 6.
Where can I get a replacement?
EagleCreeks Assortment - Reply
Thank you so much!
Lioneed Devotchenko - Reply
Hi @lioneeddev99026, You are most welcome. I'm glad the guide was helpful!
Sarah Westberg -
Past 24 Hours: 8
Past 7 Days: 101
Past 30 Days: 470
All Time: 12,296
