Lenovo ThinkPad T480s Hall Sensor Replacement
  1. Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: step 1, image 2 of 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Hall Sensor Replacement: step 2, image 1 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement: step 2, image 2 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement: step 2, image 3 of 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Hall Sensor Replacement: step 3, image 1 of 2 Lenovo ThinkPad T480s Hall Sensor Replacement: step 3, image 2 of 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: step 4, image 1 of 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: step 4, image 2 of 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Hall Sensor Replacement: step 5, image 1 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement: step 5, image 2 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement: step 5, image 3 of 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: step 6, image 1 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: step 6, image 2 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: step 6, image 3 of 3
    • Use a spudger to disconnect the cable from the Hall sensor.
  7. Lenovo ThinkPad T480s Hall Sensor Replacement: step 7, image 1 of 2 Lenovo ThinkPad T480s Hall Sensor Replacement: step 7, image 2 of 2
    • With the Phillips #1 screwdriver, remove one 3.1 mm screw from the sensor.
  8. Lenovo ThinkPad T480s Hall Sensor Replacement: step 8, image 1 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement: step 8, image 2 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement: step 8, image 3 of 3
    • Remove the sensor from the system.
Sarah Westberg
23,468 Reputation
70 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,525 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 106
All Time: 2,450
