Lenovo ThinkPad T480s Wi-Fi Card Replacement
  1. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: step 1, image 2 of 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Wi-Fi Card Replacement: step 2, image 1 of 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: step 2, image 2 of 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: step 2, image 3 of 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Wi-Fi Card Replacement: step 3, image 1 of 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement: step 3, image 2 of 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 1 of 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 2 of 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 3 of 3
    • Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
    • When reassembling, reattach the gray wire closest to the screw and the black wire on the other side of the gray wire.
  5. Lenovo ThinkPad T480s Wi-Fi Card Replacement: step 5, image 1 of 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement: step 5, image 2 of 2
    • Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
  6. Lenovo ThinkPad T480s Wi-Fi Card Replacement: step 6, image 1 of 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: step 6, image 2 of 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: step 6, image 3 of 3
    • Slide the Wi-Fi card out from the slot.
Sarah Westberg
23,471 Reputation
70 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,525 Guides authored
0 Comments
Past 24 Hours: 8
Past 7 Days: 22
Past 30 Days: 110
All Time: 1,999
