Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement Replacement
  1. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Back Cover: step 1, image 1 of 1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: step 2, image 1 of 1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: step 3, image 1 of 1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: step 4, image 1 of 2 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: step 4, image 2 of 2
    • Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: step 5, image 1 of 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: step 5, image 2 of 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: step 5, image 3 of 3
    • Remove the battery using your hand or a prying tool.
  6. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: step 6, image 1 of 2 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: step 6, image 2 of 2
    • Use the Phillips #1 screwdriver to remove the two 1.2 mm screws.
  7. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: step 7, image 1 of 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: step 7, image 2 of 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: step 7, image 3 of 3
    • Unplug the speaker cable from the board.
  8. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: step 8, image 1 of 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: step 8, image 2 of 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: step 8, image 3 of 3
    • Lift up the marked latch and remove the cable.
    • Remove the speaker.
You will have the speaker replaced and fully working. To reassemble your device, follow these instructions in reverse order.
Diego Garcia reyes
493 Reputation
5 Guides authored
Gateway, Team 1-3, Saknee Fall 2021 Member of Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 53
All Time: 839
