Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card Replacement
  1. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement, Back Cover: step 1, image 1 of 1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: step 2, image 1 of 1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: step 3, image 1 of 1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement, Wi-Fi Card: step 4, image 1 of 1
    • Use the Phillips #1 screwdriver to remove the 1.2 mm screw that's holding the Wi-Fi card in place.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: step 5, image 1 of 1
    • Disconnect the white and black coaxial antenna cables from the Wi-Fi card.
  6. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: step 6, image 1 of 2 Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: step 6, image 2 of 2
    • Slide the card out to remove it from the laptop.
Diego Garcia reyes
493 Reputation
5 Guides authored
Gateway, Team 1-3, Saknee Fall 2021 Member of Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 45
All Time: 956
