Lenovo ThinkPad X1 Extreme Speakers Replacement
  1. Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: step 1, image 1 of 3 Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: step 1, image 2 of 3 Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: step 1, image 3 of 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Speakers Replacement, Speakers: step 2, image 1 of 1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Speakers Replacement: step 3, image 1 of 1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
Kristen Gismondi
83,359 Reputation
204 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,645 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 364
