Lenovo ThinkPad X390 Speaker Replacement
  1. Lenovo ThinkPad X390 Speaker Replacement, Back Cover: step 1, image 1 of 1
    • Turn off and power down the laptop before proceeding with the guide.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
    • The screws are not removable.
  2. Lenovo ThinkPad X390 Speaker Replacement: step 2, image 1 of 2 Lenovo ThinkPad X390 Speaker Replacement: step 2, image 2 of 2
    • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
    • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo ThinkPad X390 Speaker Replacement, Battery: step 3, image 1 of 2 Lenovo ThinkPad X390 Speaker Replacement, Battery: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, unplug the battery from the laptops motherboard by pulling on the cable that attaches it.
  4. Lenovo ThinkPad X390 Speaker Replacement: step 4, image 1 of 2 Lenovo ThinkPad X390 Speaker Replacement: step 4, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the four 5.2 mm screws holding the battery in place.
  5. Lenovo ThinkPad X390 Speaker Replacement: step 5, image 1 of 2 Lenovo ThinkPad X390 Speaker Replacement: step 5, image 2 of 2
    • Using your hands, remove the battery from the laptop.
  6. Lenovo ThinkPad X390 Speaker Replacement, Speaker: step 6, image 1 of 1
    Buy
    • Using a pair of tweezers, unplug the speakers from the motherboard.
  7. Lenovo ThinkPad X390 Speaker Replacement: step 7, image 1 of 2 Lenovo ThinkPad X390 Speaker Replacement: step 7, image 2 of 2
    • Use the Phillips #0 screwdriver to remove four 2.9 mm screws securing the speakers to the motherboard.
  8. Lenovo ThinkPad X390 Speaker Replacement: step 8, image 1 of 1
    • Carefully unwind the speakers from the motherboard and remove them from the device.
Connor Handy
97 Reputation
1 Guide authored
Clemson, Team 5-1, Hunter Fall 2021 Member of Clemson, Team 5-1, Hunter Fall 2021
CLEM-HUNTER-F21S5G1
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 312
