Lenovo Yoga 6 13ALC6 Battery Replacement
  1. Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the lower case: step 1, image 1 of 2 Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the lower case: step 1, image 2 of 2
    • Use a T5 Torx screwdriver to remove the six 7.2 mm screws securing the lower case.
  2. Lenovo Yoga 6 13ALC6 Battery Replacement, Insert the opening pick: step 2, image 1 of 2 Lenovo Yoga 6 13ALC6 Battery Replacement, Insert the opening pick: step 2, image 2 of 2
    • Insert an opening pick between the lower case and the chassis at a hinge corner.
    • Pry up with the pick to release the clips securing the lower case.
    • Repeat the process on the other hinge corner.
  3. Lenovo Yoga 6 13ALC6 Battery Replacement, Release the clips: step 3, image 1 of 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the clips: step 3, image 2 of 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the clips: step 3, image 3 of 3
    • Slide the pick along the right edge to release the clips securing the lower case.
  4. Lenovo Yoga 6 13ALC6 Battery Replacement, Release the remaining clips: step 4, image 1 of 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the remaining clips: step 4, image 2 of 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the remaining clips: step 4, image 3 of 3
    • Continue sliding the opening pick along the front and left edges to release the remaining clips.
  5. Lenovo Yoga 6 13ALC6 Battery Replacement: step 5, image 1 of 3 Lenovo Yoga 6 13ALC6 Battery Replacement: step 5, image 2 of 3 Lenovo Yoga 6 13ALC6 Battery Replacement: step 5, image 3 of 3
    • Insert the pick on the hinge edge and slide along the entire edge to release all of the clips.
  6. Lenovo Yoga 6 13ALC6 Battery Replacement: step 6, image 1 of 3 Lenovo Yoga 6 13ALC6 Battery Replacement: step 6, image 2 of 3 Lenovo Yoga 6 13ALC6 Battery Replacement: step 6, image 3 of 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  7. Lenovo Yoga 6 13ALC6 Battery Replacement, Disconnect the battery: step 7, image 1 of 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Disconnect the battery: step 7, image 2 of 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Disconnect the battery: step 7, image 3 of 3
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  8. Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the battery: step 8, image 1 of 2 Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the battery: step 8, image 2 of 2
    • Use a Phillips screwdriver to remove the five 4.2 mm-long screws securing the battery.
  9. Lenovo Yoga 6 13ALC6 Battery Replacement, Remove the battery: step 9, image 1 of 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Remove the battery: step 9, image 2 of 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Remove the battery: step 9, image 3 of 3
    • Lift the battery straight out of its recess and remove it.
For optimal performance, calibrate your newly installed battery after completing this guide.
2 other people completed this guide.
Alex Diaz-Kokaisl
125,849 Reputation
592 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,529 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 162
All Time: 2,121
