Lenovo Yoga 6 13ALC6 Lower Case Replacement
  1. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Unfasten the lower case: step 1, image 1 of 2 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Unfasten the lower case: step 1, image 2 of 2
    • Use a T5 Torx screwdriver to remove the six 7.2 mm screws securing the lower case.
  2. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Insert the opening pick: step 2, image 1 of 2 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Insert the opening pick: step 2, image 2 of 2
    • Insert an opening pick between the lower case and the chassis at a hinge corner.
    • Pry up with the pick to release the clips securing the lower case.
    • Repeat the process on the other hinge corner.
  3. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the clips: step 3, image 1 of 3 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the clips: step 3, image 2 of 3 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the clips: step 3, image 3 of 3
    • Slide the pick along the right edge to release the clips securing the lower case.
  4. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the remaining clips: step 4, image 1 of 3 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the remaining clips: step 4, image 2 of 3 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the remaining clips: step 4, image 3 of 3
    • Continue sliding the opening pick along the front and left edges to release the remaining clips.
  5. Lenovo Yoga 6 13ALC6 Lower Case Replacement: step 5, image 1 of 3 Lenovo Yoga 6 13ALC6 Lower Case Replacement: step 5, image 2 of 3 Lenovo Yoga 6 13ALC6 Lower Case Replacement: step 5, image 3 of 3
    • Insert the pick on the hinge edge and slide along the entire edge to release all of the clips.
  6. Lenovo Yoga 6 13ALC6 Lower Case Replacement: step 6, image 1 of 3 Lenovo Yoga 6 13ALC6 Lower Case Replacement: step 6, image 2 of 3 Lenovo Yoga 6 13ALC6 Lower Case Replacement: step 6, image 3 of 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Lenovo Yoga answers community for help.
Spencer Day
58,680 Reputation
430 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,528 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 75
All Time: 1,420
