Lenovo Yoga 920-13IKB Battery Replacement
  1. Lenovo Yoga 920-13IKB Battery Replacement, Back Cover: step 1, image 1 of 2 Lenovo Yoga 920-13IKB Battery Replacement, Back Cover: step 1, image 2 of 2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Battery Replacement: step 2, image 1 of 3 Lenovo Yoga 920-13IKB Battery Replacement: step 2, image 2 of 3 Lenovo Yoga 920-13IKB Battery Replacement: step 2, image 3 of 3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Battery Replacement, Battery: step 3, image 1 of 3 Lenovo Yoga 920-13IKB Battery Replacement, Battery: step 3, image 2 of 3 Lenovo Yoga 920-13IKB Battery Replacement, Battery: step 3, image 3 of 3
    • Remove the four 5mm Phillips #00 screws that hold the battery in place.
  4. Lenovo Yoga 920-13IKB Battery Replacement: step 4, image 1 of 2 Lenovo Yoga 920-13IKB Battery Replacement: step 4, image 2 of 2
    • Grab the grouping of wires with your fingers close to the connector and gently pull to disconnect the battery from the motherboard.
    • The wire grouping is located underneath the thin flap near the center of the battery.
    • Do not lift the battery out before disconnection from the motherboard to prevent shortages or damage.
  5. Lenovo Yoga 920-13IKB Battery Replacement: step 5, image 1 of 1
    • Use the iFixit Opening Tool to lift the battery up enough to grab it with your hands.
  6. Lenovo Yoga 920-13IKB Battery Replacement: step 6, image 1 of 1
    • Remove the battery.
30 other people completed this guide.
Alyssa McCulloch
1,921 Reputation
9 Guides authored
Cal Poly, Team S2-G3, White Winter 2019 Member of Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
4 Members
29 Guides authored
13 Comments
What is the correct replacement battery for this device?
Stephen Prather - Reply
Nice writeup!
Tim Averett - Reply
Simple, a real simple straight forward process with the right tools of course. Thanks
Daniel Smith - Reply
Thank you, was very easy replace battery using your guide!
Andrejs - Reply
Simple and easy. Great guide to! Thanks so much
Isaac Stahl - Reply
Past 24 Hours: 4
Past 7 Days: 62
Past 30 Days: 328
All Time: 24,027
