Linksys WRT54GS v2 Front Case Replacement
  1. Linksys WRT54GS v2 Front Case Replacement, Front Case: step 1, image 1 of 1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Front Case Replacement: step 2, image 1 of 1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Front Case Replacement: step 3, image 1 of 1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Front Case Replacement: step 4, image 1 of 1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
Allian Roman
276 Reputation
5 Guides authored
Cal Poly, Team 3-4, Regan Fall 2011 Member of Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,077
