Logitech G29 Driving Force Force-Feedback Motor Replacement
  1. Logitech G29 Driving Force Force-Feedback Motor Replacement, Force-Feedback Motor: step 1, image 1 of 1
    • Remove the six 32mm long 4mm allen screws from the faceplate of the steering wheel
  2. Logitech G29 Driving Force Force-Feedback Motor Replacement: step 2, image 1 of 1
    • Now, Remove the six 10mm long #00 Phillips head screws from the back of the steering wheel.
    • Gently lift off the steering wheel from the hub.
  3. Logitech G29 Driving Force Force-Feedback Motor Replacement: step 3, image 1 of 1
    • Carefully unplug the wire connector from the motherboard of the steering wheel
  4. Logitech G29 Driving Force Force-Feedback Motor Replacement: step 4, image 1 of 2 Logitech G29 Driving Force Force-Feedback Motor Replacement: step 4, image 2 of 2
    • Using the #1 Phillips head screwdriver remove the three 30mm long screws that are behind the steering wheel.
    • Gently pull the paddle assembly off from the base of the device and carefully thread the connector through the hole in the center.
  5. Logitech G29 Driving Force Force-Feedback Motor Replacement: step 5, image 1 of 1
    • Remove the 15.9mm long silver screws on the bottom of the base of the wheel with a Phillips #1 screwdriver.
  6. Logitech G29 Driving Force Force-Feedback Motor Replacement: step 6, image 1 of 1
    • Now remove the four 7.3mm long silver screws from the motherboard using a Phillips #2 screwdriver.
    • Then, carefully remove the seven plastic connectors from the motherboard. Make sure to avoid pulling by the wires and to only pull on the plastic
  7. Logitech G29 Driving Force Force-Feedback Motor Replacement: step 7, image 1 of 1
    • Remove the two black screws using a Phillips #2 screwdriver.
  8. Logitech G29 Driving Force Force-Feedback Motor Replacement: step 8, image 1 of 1
    • Remove the four 12mm long screws with the phillips #1 screwdriver
  9. Logitech G29 Driving Force Force-Feedback Motor Replacement: step 9, image 1 of 1
    • Now that the complete driving assembly is out you can replace it as needed.
2 other people completed this guide.
3 Comments
how much is this part
glenn castillo - Reply
where do u get repayment parts ?
callum smith - Reply
Where can we find some replacments parts ?
super miaoumix - Reply
Past 24 Hours: 15
Past 7 Days: 88
Past 30 Days: 455
All Time: 7,436
